Thread: Roots Growing Under Tiles?
    lovemy3azboys's Avatar
    Mar 2011
    Phoenix, Arizona
    63
    I have another post on this forum asking about shocking & running the filter. I have a new problem & not sure which forum to post it as I didnt find previous posts on this topic.
    In the process of shocking, decided to pry some loose tiles to see if there is algae under them. I did find some but also found what looks like plant material. Anyone run into this problem?
    25,000 gallon plaster dive pool, Eclipse sand filter, 1 HP Centurion pump, Baracuda G3, TF-100 Test Kit
    Mar 2011
    Phoenix, Arizona
    63
    Re: Roots Growing Under Tiles?
    Well, after not finding any answers online we decided to pry underneath it all. We found there is a horizontal crack in the cement underneath the tiles that we believe has grass growing from the adjacent dirt/grass area. We removed the concrete that appears to have been added over the crack & found more grassy material. We chiseled it all & will shock at mustard level tonight in the hopes that will get it all. Once the OCLT is good we will drop the water level & fix the crack & retile.
    Still hoping to hear from anyone who has seen this before...
    22,553
    Your plan sounds good. I don't know if you need to shock at that high a level, but it won't hurt. Once you have it cleaned out you could probably seal it with caulking until you can get it sealed permanently.
