Thread: Raypak Ignition Trouble
    I have a 266 with electronic ignition, but the spark is too weak to ignite the gas (I can easily light it with a match).
    I pulled out the PC board, removed the high tension wire and tried another wire held close to the sheet metal and the spark was still weak.
    Is this a PC board issue?
    7000 Gallon inground pool with SWG and gas heater
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Re: Raypak Ignition Trouble
    You would first have to see if you are getting a full 24V to the igniter. Could just be the igniter is all that is wrong. Do you smell gas when it's trying to light? Do you hear a click or feel a click from the gas valve?
    Be very careful when messing with gas!
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Emailed Raypak, and got a response withing an hour -- suggested I check the voltage to the board (which was good).
    I got a new board, installed it today, and everything works again.
