Thread: Unions on intake/outflow
    Jun 2011
    San Diego California
    88
    I'm swapping my old pump out and when I b ought the new VS, they suggested I purchase the unions. Is there a reason why I want unions on the two lines on the pump? Is it only for ease of changing the pump or removing it in the future?
    IG, 13,000 gal, concrete, DE, VS Intelliflo Pump, Intellichlor SWG
    San Diego, Ca.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Unions on intake/outflow
    Makes it much easier to work on your system. If you find you didn't get a tHreaded connection tight, you can disconnect the union and tighten it or remove it and add dope. Well worth it.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Where to source the unions? HD doesn't have the male thread in unions.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Jun 2011
    88
    Quote Originally Posted by maxepr1
    This is why I asked if they are worth it, as the onyl ones I can find are the slip ones. So if I ever change plumbing, I have to keep the union and the attached PVC as there is no pulling it out later. Lowes had unions with one side threaded however.
    San Diego, Ca.
