Results 1 to 8 of 8
Thread: Dirt from return when switching pump from low to high?
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    So this morning I switched the pump from low to high to do some vacuuming and immediately fine brown dirt started coming out of the return. In horror I turned it off immediately. I just replaced the gasket in the multi-port last year. What could be causing this?
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    30,419
    Re: Dirt from return when switching pump from low to high?
    When did you last clean/backwash your filter?
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    2 days prior. I backwashed after vacuuming for the first time this season.
    Then I adjusted TA, pH, added CYA to the filter and brought it up to shock level. I let it run for 1 day on high. The water looked great the next day so I turned the pump down to low. It ran for another whole 24 hours on low until this morning.
    I went out today to do some finishing touches with the vacuum and noticed the dirt when I flipped to high to hook up the suction plate.
    22,548
    It may have been some residual in the line that settled out on low speed but the velocity of high speed was enough to carry it out.
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    I let it run for a good 30 seconds. It was just continuously shooting a medium brown jet of dirt into the almost sparkly pool. I'm starting to wonder if I'll even be able to use the low speed on my filter.
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Does "high rate" sand filter mean I always need to run on high?
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    I had the same problem last year. I think my sand was channeled, so I deep cleaned the filter by removing the top and shoving a garden hose down through the sand and moving it around, being careful of the laterals. You need to let the hose run until the water overflowing from the filter runs clear. Then do a good backwash/rinse. That solved the problem. Good luck
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    22,548
    Quote Originally Posted by JesseWV
    No it just means it's capable of high flow rate. It doesn't mean you have to have a high flow.
