Thread: Opening time?
    May 2011
    Los Angeles, CA
    228
    Opening time?
    Hi Everyone!
    When is the time to open the pool? Mine is under covers which blocks out all sunlight but i am not sure if the temperature has risen above 60F.
    Should i pull off the cover and start shocking/ balancing the pool if the temperature is above 60F or can i wait till I want to open it?
    Thanks!
    Suley, West Hills, CA
    IG 23000 Gallons with IG Spa Gunite plaster, Pentair Intelliflo VS 3HP, Pentair Clean & Clear Plus 420 Cartridge filter, Teledyne Laars One series 400,000 BTU Nat Gas Heater, Hayward Max Flo 1HP Single Speed Spa pump, Noisy Spa blower, Dolphin Deluxe 4 robotic vacuum.
    Re: Openign time?
    Our pool is open right now. I liveinoklahoma and its around 70's already.
