Thread: adding chlorine and acid at the same time
    Apr 2010
    Southern California
    83
    I use 12% chlorine and 34% muriatic acid and for the last year or two I have always waited about 30 minutes between adding these two chemicals, but I can't seem to remember who told me not to add both at the time time and what the reason was?
    What if I'm only adding a little of each?
    Can someone confirm?
    12,000 gallon IG (newly re-plastered) pool, Pentair 3/4hp pump, DE filter, TF-100 test kit
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: adding chlorine and acid at the same time
    Always add chemicals to the pool separately. Our recommendation is to wait 1 hour between chemical additions and to add them slowly in front of the return. This allows the first chemical to disperse throughout the pool before the second one is added.
    See this link: http://www.troublefreepool.com/can-i...me-t14886.html
    If you add chlorine and acid at exactly the same time in the same place you will produce chlorine gas, which is highly poisonous. As soon as they are properly mixed into the bulk pool water the risk goes away and everything is fine. Waiting an hour makes sure everything is totally safe. In reality shorter wait times are almost invariably fine, but when it comes to hazards like chlorine gas it is nice to be totally extra super safe just because.
