Thread: Suction Side Leak Fix
    Hi;
    My pool has a suction side leak jsut below the skimmer, very expensive to fix. I also have a return side skimmer called pool skim that work great for leaves, etc.
    My question is:
    1. Is there any reason I couldn't run a pvc pipe from a couple feet down in the pool to the surface and along the ground to the pump as a temporary fix and simply plug up the suction side skimmer. The return side skimmer would still catch all the debris.
    Thanks for any help.
    Gary
    IG Pool 20,000 Gallons Gunite-Hayward 1 HP Super Pump-Doheny Discovery Pool Cleaner
    Pentair Sand Filter-Raypac Pool Heater 266,000 BTU-PoolSkim Pool Skimmer-TF 100 Test Kit
    30,419
    Re: Suction Side Leak Fix
    Sure. Remember your skimmer basket has been eliminated to so any large objects the pipe sucks in will go straight to the pump strainer basket.
    Thanks for the reply, Dave, perhaps I could put some sort of strainer on it. It would be down 3-4 feet so most of the surface debris would have been already be caught by the return skimmer.
    Regards,
    Gary
