Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: I've been a bad/lazy pool owner
    Jan 2011
    Riverside, CA
    352
    We just hit our 1 year anniversary for the pool. During the first summer I was testing and brushing every week.
    Well over the winter I got lazy. I'd brush the pool only 1 or 2 times a month. And I only checked the levels about the same ...
    It's starting to warm up and I'm ready to get back on schedule.
    Overall the pool did very well this winter. The Liquidator was doing a pretty good job and I never ran below a 1 on the FC. My pH did stay on the higher side, so I went through about 3 Gallons of Acid over the winter.
    Here is my last reading:
    pH - 7.8 (I already added 4 Qts of Acid)
    FC - 2.5 (drop test)
    CC - less than .5
    TA - 60
    CYA - 40-50
    Pool Store info:
    TDS - 1400
    Hardness - 365 (I think one of my chemicals is bad)
    The pool does collect dust/dirt along a couple of the corners. I assume there is some algae in there too. I brush it up into the pool and it is gone for probably 1-2 weeks.
    Is there any reason to bring the Chlorine level up to a Shock Level? Or just back to where is should be for the CYA.
    The Pool Store didn't think the TDS would be a problem until it was much higher.
    I've been running the Liquidator for about 9 months, it might be time to shut it down and clean it out (I'll start that thread in the LQ Forums).
    I cleaned out the Pool Filter about 6 weeks ago, it was very dirty. I think I cleaned it 5 times in the last year.
    Anything I'm missing?
    40x20 Free Form IG Pool (aprox 29,000 Gal, 140 Perimeter, depth 3'6"-7', Baja Shelf, 8x8 Free Form Spa) - Gunite Shell, Pebble Plaster Finish, Poured Concrete Coping - 3 Deep Heat Returns - Jandy LXi400 Gas Heater (400,000 Btu) - Jandy Variable Speed Pump JEP 2.0 - Jandy CL 600 Filter - HASA Liquidator - Jandy PDA 6 w/ Remote - 4x Jandy WaterColors Pool LEDs - 48" Gas Fire Pit - 6x Gas Tiki Torches - 12'x15' U-shaped BBQ Island (Firemagic Equipment)
    http://www.troublefreepool.com/new-p...ca-t28413.html
    Feb 2008
    Denton, TX
    5,061
    Re: I've been a bad/lazy pool owner
    If you have algae, then you should shock your pool.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by Nightmare
    Algae should not be in the pool if it is properly balanced/maintained. I would raise your pool up to shock level and do a OCLT (see my sig). If you pass (and your CC level is below 0.5 ppm), all is good and let the FC level come back down on it's own, if you do not, you are already into the shocking process and can continue.
    No need to worry about TDS, it is not a problem for a properly maintained pool.
    This I am not sure about. Maybe someone else can chime in
    Jan 2011
    Riverside, CA
    352
    It must be just dirt in the pool. I checked the CYA again.
    Before:
    pH - 7.5
    FC - 3.0
    CC - 0.0
    CYA - 50
    Added 3 gallons of 12.5% Chlorine
    Midnight Reading
    FC - 20.5
    CC - less than .5
    7:45 am Reading
    FC - 19.5 - 20.0
    CC - 0.0
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    You numbers look good, but from you pictures it looks like the "dirt" may be on the side of the pool? If this is what you brush and it leaves and comes back, I would guess it is not just dirt or it would not be on the side. If there is something on the side, it could organic, or inorganic staining. Am I seeing your picture right?
    Jan 2011
    Riverside, CA
    352
    Yes, there is something on the sides that the Pool sweep can't reach. I brush it up into the water and it dissipates like a cloud of dust. It doesn't seem to come back for over a week. We do have a lot of dust up here on top of the hill.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I would be surprised if dust would accumulate on the walls like that, especially with less preponderance on the bottom. Since it brushes off fairly easily it is not a stain. That leaves use with some sort of organic. I am not an expert on Mustard Algae, but that is looking like it to me. Here is the poolschool article on Mustard Algae: http://www.troublefreepool.com/pool-.../mustard_algae
    30,402
    It's hard to be absolutely definitive but I believe you have mustard algae as well.
    My suggestion would be to run your chlorine levels up around 10ppm and brush those spots where it accumulates every day for about 4-5 days.
    Then let your FC drift back down to normal (4-6ppm) and see if it reappears.
    Jan 2011
    Riverside, CA
    352
    Last week I opened up the Liquidator full blast to wash out the last gallon of chlorine.
    I took it apart on Monday (4/16), cleaned it out and filled it back up with 8 gallons of chlorine.
    Yesterday (4/17) I brushed the pool again, the 'stuff' was back on the lower section of the walls around the steps.
    I took a drop test of FC = 10.5
    My CYA is somewhere around 50, so I should be well above the Mustard Algae minimum.
    We have a lot of dust (and I assume pollen) up here.
    Is there a test I can run for Mustard Algae?
    Is there a problem with using something like an algaecide? (it is going to take just over 3 gallons of chlorine to reach the Mustard Algae Shock Level)
    I found this on the net (http://www.poolmanual.com/manual/algae.html#howmustard)
    Aug 2011
    Metro Atlanta, Georgia
    161
    I used this, pool-school/mustard_algae but used this chart( chlorine-cya-chart-t2346.html#p18157 ) for chlorine levels, which shows 29.4 ppm. I have not been bothered with it since. Basically, burn it up.
    My cement pond is a 36K gunite 20X40 built in mid 1960s, Hayward S244S filter, Aquarite SWCG, Jandy 1.5HP 2sp, TF-Test kit and Nitro Wall Climber
    Butterfly's Avatar
    South Carolina
    10,045
    Nightmare, it sure sounds like mustard algae to me, too
    If you follow the links Buford listed, you can get this under control.
    I hate that this happened to your new beautiful pool, but as you said in your subject title,
    "I've been a bad/lazy pool owner"
    Once you get this under control, I doubt if you ever let it happen to your pool again!
    You're done SLAMing when:
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Nightmare, that link you posted says to use "metallic algeacide" aka copper. You have been around here long enough to know to stay away from that! Chlorine is the way!
    Jan 2011
    Riverside, CA
    352
    We have some people coming over this weekend. I think if I start the Mustard Shock now, the FC level is still going to be over 20 by Saturday. I can't find that maximum swimming FC number, is the the same as the Normal Shock level?
    How does this plan sound?
    Maintain FC level at 10+ through the end of next week
    Brush pool every day from now until Sunday, then stop for several days
    If the 'Stuff' Reappears can I assume it is NOT Mustard Algae? FC level if over the Min Mustard Level for my CYA
    If nothing reappears then I'm still ok, slowly drop FC below the Min Mustard Level (Back to normal target for CYA)
    - If the 'Stuff' only reappears at that time, assume it IS Mustard?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    The recommendation is up to (but not above) normal shocking level for you CYA level.
    Although I have heard discussion on having your FC at 15% of cya level keeps mustard algae growth from occuring in bulk pool water, I would not rely on that to "prove" it's not mustard algae...MA is really tough to predict and kill.
    Aug 2011
    161
    I don't know if your plan will work or not. I also am confused as to where the 10 ppm with cya at 50 is coming from, I get 29+. Whoever wrote the instructions in Pool School did a fine job, it worked for me. I can only suggest following the instructions, completely.
    Jan 2011
    Riverside, CA
    352
    I did a standard Shock last week (FC 20.5). It held with less than 1.0 ppm drop overnight.
    There is another number for the Mustard Algae Minimum FC here (chlorine-cya-chart-t2346.html#p18157)
    I'll keep it above the 7.5 FC (for a CYA of 50) just in case I misread the correct CYA level. Here is part of the chart.
    CYA ........... Min FC3 ..... Target FC ...... Yel/Mstrd Min ...... Shock FC ..... Yel/MstrdShock
    0 ................. 0.071 ........... 0.111 ................ 0.151 .................. 0.641 .............. 1.501
    10 ............... 0.81 ............. 1.21 .................. 1.61 .................... 4.5 .................. 7.1
    20 ............... 1.51 ............. 2.4 .................... 3.1 ..................... 8.3 ................ 12.7
    30 ............... 2.2 ............... 3.5 .................... 4.6 ................... 12.2 ................ 18.2
    40 ............... 2.9 ............... 4.6 .................... 6.1 ................... 16.0 ................ 23.8
    50 ............... 3.7 ............... 5.7 .................... 7.5 ................... 19.8 ................ 29.42
    60 ............... 4.4 ............... 6.8 .................... 9.0 ................... 23.7 ................ 34.92
    Jan 2011
    Riverside, CA
    352
    I brushed the pool several days in a row before the weekend
    FC started out at 12.5 Last Saturday and it has been slowly dropping.
    No signs of anything yellow in the shallow end after 5 days of no brushing.
    Today's tests
    pH - 7.5-7.6
    FC 4.5
    CC 0
    TA 50
    CYA 40-50
    I added 2 cups of 12.5% Chlorine and I plan to keep the FC at 5-6 for the foreseeable future.
    I want to add about 6 lbs of Baking Soda (actually Bioguard Balance Pax that I purchased a full year ago). I searched the forums, but I don't see the recommended way to add the Baking Soda. Do I dissolve it in a bucket of water and pour that into the pool or?
    38,239
    Recommended Pool Chemicals states how to add various chemicals.
    Baking soda can be added by spreading it across the surface of the deep end of the pool.
    Jan 2011
    Riverside, CA
    352
    Thanks. I used the bucket and poured it in several spots
  20. Back To Top    #20
    Jan 2011
    Riverside, CA
    352
    I'm pretty sure I don't have any Algae.
    I accidentally let the Chlorine level drop down to 0.5
    And nothing seemed to happen...Even without brushing for a week.
    I refilled the LQ and added a gallon of 12% to the pool. It should be back to normal by the end of the day
