When Should Salt be Added?
onBalance
In The Industry
Jul 25, 2011
1,487
Utah
In our industry, there seems to be some consensus to wait 30 days before adding salt to new plaster pools, yet some say it is okay to add salt within a couple of days of filling the pool. So who is right?
To answer that question, let’s first take a look first at what happens in the initial days and weeks of a new plaster surface. When plaster is applied and a new pool is filled, the cement portion of the new, hardened pool plaster contains about 10 to 15% calcium hydroxide, the rest being primarily calcium silicates, aluminates and carbonates. These latter products are durable and relatively insoluble in water.
On the other hand, calcium hydroxide, having a pH of about 12, is softer, somewhat soluble, and can be dissolved from a plaster surface even by typical balanced tap water. Indeed, the Saturation Index as a maintenance tool to protect calcium carbonate is not applicable to fresh plaster (i.e., less than a few weeks old) that has some calcium hydroxide on the surface.
This is why the pH of the water in a freshly filled pool usually rises noticeably as soon as the pool is being filled. High pH calcium hydroxide dissolves from the plaster surface and into the water, shooting the pH up. Once the new plaster surface is carbonated (which means the calcium hydroxide is converted to calcium carbonate) this process stops.
Since dissolved calcium hydroxide also converts to calcium carbonate in the pool water, this is the source of so-called “plaster dust” in new plaster pools. When undergoing a traditional start-up process, carbonation of the surface usually lasts about 1½ to 2 weeks… which is why new plaster dust is generated for that long – and then stops. At that time the pH becomes stable in the pool, since new hydroxide is no longer being dissolved into the pool water.
The onBalance team decided to conduct an experiment in a laboratory setting to determine what effects salt may have on fresh plaster and on the curing process. The following are the details and results of our simple experiment.
On Day 1, four good quality plaster coupons were formed and allowed to harden.
On Day 2 the coupons were placed into four separate water tanks. The water in all four tanks were balanced to the same parameters; Temp = 70°F, pH = 7.6, TA = 160 ppm, CH = 200 ppm. The tanks were capped to slow down carbon dioxide out-gassing. (When water loses CO2, the pH rises with no change in TA).
Day 3, after 24 hours in water, the pH of the water was recorded and in all four tanks the pH rose to 8.4, indicating that some hydroxide from the plaster surface had been dissolved away and into solution. (Note that this occurred even in balanced water). The pH would have risen even higher if the beginning TA of the water was lower and around 80 ppm.
Then Tanks 3 and 4 had 3000 ppm of salt added. Acid was then added to all water tanks to lower the pH to 7.6.
On Day 4, the pH in Tanks 1 and 2 rose slightly to 7.7. But in Tanks 3 and 4, the pH had risen much higher to 8.6, indicating a significant effect on the plaster surface material. Acid was added to Tanks 3 and 4 to lower the pH back to 7.6.
On Day 5, the pH in Tanks 1 and 2 was 7.8, but in Tanks 3 and 4 the pH rose to 8.4. Again, the pH raised more in the Tanks that had the salt added. Acid was added again to all Tanks and lowered to pH 7.6.
On Day 6, the pH in Tanks 1 and 2 was 7.7, but in Tanks 3 and 4 the pH was 8.2. The pH was not adjusted downward.
On Day 11, the pH in Tanks 1 and 2 was 7.8; the pH in Tanks 3 and 4 was 8.4. At this time, 3000 ppm of salt was added to Tank 2.
On Day 17, the pH of Tank 1 was 7.8; the pH of Tank 2 was 8.0, the pH of Tank 3 and 4 was still at 8.4. This data shows that the salt added to Tank 2 after 11 days had a slight effect on the plaster coupon in comparison to Tank 1. The pH is all tanks were lowered to 7.7.
On Day 21, the pH of all tanks was identical at 7.8.
The results obtained suggest that adding 3000 ppm of salt does have a negative effect on plaster if added in the beginning at startup and up through the first two or three weeks. When salt is added to water containing fresh plaster coupons, the pH of the water increased significantly higher than normal. This indicates an additional amount of calcium hydroxide is being dissolved and removed from the plaster surface. This likely causes an increase in the porosity of the plaster finish, which weakens and ages the surface prematurely.
The data also indicates that the negative effect of salt on new plaster only lasts about three weeks. As mentioned above, this is because a new plaster surface becomes carbonated; meaning that any calcium hydroxide (on the plaster surface) that is not dissolved and converted to water hardness and/or plaster dust is slowly being converted into calcium carbonate during the first three to four weeks of being filled with balanced tap water. This conversion creates a protective and more durable plaster finish. It appears that once the plaster surface has been sufficiently and properly carbonated, salt does not have the same negative effect on calcium carbonate as it does on calcium hydroxide.
Our experiment used well-made plaster coupons, which received proper curing, and positive Saturation Index water. If, in the field, proper plastering practices are not followed closely, which results in a lower quality finish, more time may be needed before salt should be added. It appears that the recommendation to wait 30 days before adding any salt is appropriate for most plaster pools, including quartz and pebble pools.
For proper plastering practices, see this post: ten-guidelines-for-quality-pool-plaster-t42957.html
We know that 3000 ppm salt lowers the saturation index by about 0.2 units, but what you saw would seem to be some other effect since the pH went up well beyond just 0.2 units. Perhaps the salt interferes with the calcium carbonate formation process giving more time for the calcium hydroxide to dissolve into the water. The saturation index is only about thermodynamics and not about reaction rates. Even with positive saturation index water, if the salt slowed down the calcium carbonate formation rate then that might be what is going on.
I'm not sure how that happens, but I do know that high chloride levels interfere with formation of passivity layers on stainless steel forming metal chlorides instead of metal oxides. Perhaps something similar is happening with plaster forming calcium chlorides instead of calcium carbonates. Though calcium chloride is soluble, it may form long enough on the surface to slow down calcium carbonate formation. This is just a guess on my part, however.
Great info! Thanks!
we just happen to be starting up a new plaster pool. its about 12,000 gallons. did an acid start up 1 week after we started filling the pool as several leaks threw us off our startup time schedule. so I added 6 gallons of acid on friday. brushed for like 1 hr. now owner is brushing twice daily until we get back to the pool on tuesday. the system is still not on due to the leaks. leak detector is coming wed and will find and fix the leaks. the skimmer line and return lines were pressure tested and found to be leaking. we got some digging to do wed.
anyway great post. so we have to wait 30 days before adding salt?
The results of this experiment indicate that one SHOULD WAIT 30 days before adding salt. That is my advice.
My interpretation of this experiment is that a high content of "chloride" in the water makes calcium hydroxide more soluble and therefore causes more dissolution of that compound faster which is why the pH rises so high and quickly.
When salt is NOT added too early, it appears that more calcium hydroxide in the plaster remains in the plaster and is converted into "carbonate" intact, which is good.
Reactions: prasadkm0204
In my opinion, an acid start up is detrimental to the long-term durability and aesthetics of pool plaster. I know some pool people will disagree with me, but I feel that there is a lot of misunderstanding about new pool plaster start-ups and the chemistry of cement curing. In short, an acid start up simply etches the surface (as seen under a microscope) and will allow dirt and minerals to stick to the surface easier and more permanently.
Keeping the plaster surface more smooth and dense with a bicarb startup or "positive CSI water" for first month, helps prevent future staining and will result in easier removal with an acid wash if stained after a few years. It might be helpful to read my post on "Why Bicarb start-ups Works" in this Deep End forum.
An acid start up is a short-term fix. It does help remove plaster dust which can adhered to the surface and even improve its' appearance. However, many service techs have confirmed to me that after a period of time, pools that had an acid start do not look as good as those that had a Bicarb start up, which is also my personal experience. If one wants the plaster surface to last and look good for many years; don't do an acid start-up.
I just wish a bicarb startup was easier to do. Acid starts are very easy, which makes them attractive despite the long term issues. Maybe it is just a lack of good write-ups. The write-ups I have seen call for some semi-custom equipment to insure high TA before the water enters the pool.
You are right Jason, that is a draw-back to doing a proper Bicarb startup. I wish it was easier too.
In the alternative, if I am not called in soon enough, I do a "delayed" Bicarb start-up as soon as I can after the pool is filled with water. At the very least, a positive CSI "Traditional" works pretty well.
Thanks for the info.
Sounds like resurfacing a pool can get really time consuming and complicated. I sub the resurface job but I'm the one left brushing and brushing and starting the pool up....cleaning the filter etc etc...basically baby sitting the pool.
This will be the last resurface job I do. Just don't have the time for large repair jobs.
When I do a job I like to do it perfect. I tend to spend way too much time on these reno jobs.
But thanks for the info. I think I will stick to SWG's and pool management..
I should have mentioned that doing a "delayed" (after the new plaster pool is filled) bicarb startup is as simple as performing any other startup program. No need of any special equipment that is used to pretreat the tap water. It eliminates the difficulty of keeping the pH in check, and prevents it from climbing rapidly above 8.4 for the first few weeks. It is also easy to balance the water afterwards. And of course, as stated before, is much better on and for the plaster surface.
