Results 1 to 9 of 9
Thread: pump size
    Mar 2012
    spain
    48
    pump size
    hi
    this is my pump
    my filter has 150 liter of sand
    pool have +-35.000 liter of water
    i have pump running 1 hour and in summer 1.5-2 hours
    i know this is too little
    but howmuch should it be normally?
    Jul 2009
    London and France
    574
    Re: pump size
    Unless you are pumping some serous head you would be better of financially with a pump half or less that size. my pool is larger than yours and I am running a much smaller pump so I get better filtration, longer pump run time and a lot less electricity.
    Mar 2012
    spain
    48
    Re: pump size
    so howmuch liter this one pumps in 1 hour?
    and what size best to get?
    Jul 2009
    London and France
    574
    Re: pump size
    My pump is 3/4hp with low head loss and pumps roughly 10,000 litres/hour which would be fine for your setup too, you could even go smaller 1/2hp and 8,000 litres/hour unless you have extras like fountains, solar etc. How many skimmers/returns and main drains?
    Mar 2012
    spain
    48
    Re: pump size
    hi
    so howmuch hp is my pump now?
    i dont have any fontains or anything
    good question
    i have hole 1 up where there is a filter behind that take in water
    also there is 1 hole in the botom that take in water
    then in the side there is 1 hole where to connect the vacuum cleaner
    and 2 holes that blow the filtered water back in th pool
    Jul 2009
    London and France
    574
    Re: pump size
    Quote Originally Posted by speed
    hi
    Nearly 2hp
    Mar 2012
    spain
    48
    Re: pump size
    hi
    i have this one laying aroundm, dont know if its still working
    but does this sound more like it?
    also are there any new kind of pumps which take less energy?
    Mar 2012
    spain
    48
    Re: pump size
    ok my pump failed and is stuck
    what would be the optimal size for my pool that i need to buy?
    thabk you
    Mar 2012
    spain
    48
    Re: pump size
    i found this one
    is this any good?
    Potencia nominal: 550 Vatios
    Conexión a la red: 230 Voltios / 50 Hz
    Cabezal de bombeo máximo: 12 m
    Caudal máximo: 12 m³ / h
    Entrega de presión máximo: 1,2 bar
    Rango de temperatura: 35 °C máximo
    Dimensiones bomba: 540 x 210 x 300 mm
    Peso total: 9,71 kg
