Thread: Dichlor - then bleach method
    Hi, I am a beginner when it comes to maintaining a spa (hot tub) & a new member to TFP. I was interested to read about the Dichlor then bleach method & was wondering if anyone could explain this method to me. Regards, Dave. Perth Western Australia
    Aug 2011
    Virginia Beach
    295
    Re: Dichlor - then bleach method
    I've yet to start on it, but my plan is much the same as yours. I'm planning to start with granules/pucks until the CYA is good, then switch to liquid.
    Read pool school. I know it looks like a lot, but it's really not as bad as I had anticipated. I sat down and read it a few nights ago. I'd already picked up most of it bit by bit reading through the posts here.
    pool-school/
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
    Mar 2007
    San Rafael, CA USA
    12,082
    See Using Chlorine in a Spa. I recommend lowering the TA to around 50 ppm and adding 50 ppm Borates.
