Results 1 to 12 of 12
Thread: My first TF-100 test results
    Dec 2011
    Prosper, Texas
    124
    Here are the results of my 1st test with my TF-100 kit. (The speedstir is awesome)
    FC - 2.5
    CC - 0
    TC - 2.5
    PH - 7.5
    T/A - 130
    CH - 160
    CYA - 50
    based on the pool calculator aside from adding some bleach it looks like the only concern here is the CH. How quickly should I address this? and whats the best method. Having trouble finding deicer in Texas but someone said to try tractor supply. Any brands I should be looking for or should I just get some hardness plus from Leslie's?
    Any other thoughts based on these numbers? TIA
    21,000 gallon pool w/spa, Pebble Sheen, Hayward EcoStar variable speed filter pump, Hayward DE6020 Filter, Hayward 400FDN Heater, Stenner pump with 15 gallon tank, Clear O3 ozone system, Hayward Goldline PS-8 controller, Hayward 6060 cleaner pump, Polaris 280 cleaner, Hayward EcoStar variable speed water feature pump.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: My first TF-100 test results
    Since we rarely need de-icer and it is also the off-season for it, you are probably better off buying hardness increaser. You can check your local wal-mart and see if they have any in their garden/outdoor section. That will be less expensive than going to a pool store.
    You should also keep an eye on your TA once the CH is in range. If your pH starts going up you will need to lower the TA to try and keep pH stable.
    Love TFP? Become a
    TFP Supporter!
    38,262
    Well, zea beat me to a response ... here are my thoughts (which are basically the same):
    Given your numbers, I get a CSI of about -0.23 which is within range.
    May want to consider lowering your TA if your pH tends to rise (this will lower your CSI)
    I would not bump up the CH too much as it will tend to rise as water evaporates and requires water change to get rid of it.
    With the CYA of 50 you need to keep your FC between 4 and 8 at all times.
    I see in your signature an inline chlorinator listed ... you are not actually using it anymore are you?
    Dec 2011
    Prosper, Texas
    124
    Thanks guys I'll check out Walmart and add half what I think I need and verify with the next test.
    I have less than a tablet in the inline, I plan to only use it when out of town now that I'm moving to the the bbb method.
    30,411
    What does your water look like? Is it crystal clear?
    Dec 2011
    Prosper, Texas
    124
    Yes it is very clear and sparkles in the sun.
    30,411
    Wonderful. Then I would suggest your bring the FC up to about 4-6ppm for the rest of the summer and enjoy the pool.
    No hurry on the CH, but when you find a good source get enough to get your pool up to 300 and your all set.
    Dec 2011
    Prosper, Texas
    124
    so over the past week aside from bleach as needed and 2 inches of water to top it off I also added 12 lbs of HTH Calcium Plus (less than what was suggested to see the impact)
    Here are my results one week later.
    FC - 4.5
    CC - 0
    TC - 4.5
    PH - 7.7
    T/A - 120
    CH - 270
    CYA - 35 (after reading the tips from Jason I am more confident in this score as compared to my 1st one)
    Temp 77
    should I leave things as is or make some adjustments? Water is very clear.
    Thanks
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Looks good! Might lower your TA a bit and bump CYA up to 50.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Cajun, are you salt water?
    Dec 2011
    Prosper, Texas
    124
    Quote Originally Posted by maxepr1
    No salt. I have an inline chlorinator but it's been empty the past 2 weeks since moving to BBB. I plan to use it when I'm out of town for multiple days.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Ok, then 35 CYA is ok. It's on the low end but your good.
