Thread: Stripped threads on Hayward DE6000 at air relief valve?
    Mar 2012
    Parkland, FL
    11
    I have an older Hayward DE6000 that has stripped threads where the manual air relief valve and pressure gauge is located.
    Couple of questions?
    Whats the material of the filter body?
    Has anyone had any luck with gluing? J&B weld, Epoxy resigns and fillers West System is what I have used (Marine industry)
    What kind of materials are Pool Chemical tolerant, I know PVC and Stainless but about others Nylon brass copper,.
    Solutions
    Drill and tap a fitting into the existing hole
    Use a marine Thru-Hull Fitting with 1/4" three way, one to mount and the other for a pressure gauge and bleeder.
    Thanks in advance
    Ken
    Pool 22320 Gallons IG Plaster-DE Filter-2Hp & TF100 Test Kit.
    Mar 2012
    Parkland, FL
    11
    Re: Stripped threads on Hayward DE6000 at air relief valve?
    Quote Originally Posted by ZooMan
    Solutions
    Thanks in advance
    Anyone have any thoughts on this? I'm leaning towards J&B weld and then tapping 1/4" pipe.
    Thanks again
    Ken
    22,542
    It looks like you can replace the Relief Valve/Gauge Adapter Assembly for about $20. Here's the part number DEX2400S. You'll also need the o-ring that goes under it.
    I wouldn't try repairing it for that amount.
    Mar 2012
    Parkland, FL
    11
    Thanks
    I have address the stripped threads on the housing and not the relief valve. I'm looking for info on the filter body.
    Any Ideas.
    Ken
    22,542
    If the threads in the filter top are stripped then your best bet is either another filter top or a bulkhead fitting through the hole if it won't interfere with anything inside the filter.
    Just actually found this thread i have the same exact my threaads are stripped on a de4800 tank which is pretty much the same as you have i tried everything wrapping with teflon tape and still leaks and wont tighten was wondering what you did to fix it did you use a bulkhead fitting?
