Thread: Buying CYA
    Columbia, SC
    22
    Buying CYA
    Is it worth buying CYA? I had a new vinyl liner installed over the winter and fresh water was put in. I've got it all cleaned up and it's ready to go but there's no CYA in the water (and I mean no) so it's burning through chlorine. I currently use the liquidator but before my rebirth I used pucks and powdered shock. I find the pucks build the CYA up pretty rapidly and I've got a bucket of them so I was just going to use them until the CYA is in the right range and then switch back to bleach. I'd be interested in hearing whether people think that's a good approach and if not why.
    20K gal, vinyl, 3/4 HP pump, Hayward sand filter
    38,262
    Re: Buying CYA
    Sounds like a plan since you already have them. Have you calculated how much cya each tablet will add in the poolcalculator?
    You just need to be aware and it seems like you grasp the concern of getting cya too high.
    Nov 2010
    Calera, Al
    271
    Re: Buying CYA
    You can use the pucks till your cya reaches around 50 then switch on the liquidator.
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    22,543
    Re: Buying CYA
    Just to reinforce. I'd use them till I got to where I wanted to be with the CYA then switch to bleach.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Re: Buying CYA
    I also do that every spring. I've had pucks in my strainers for the last 2 weeks and prior to opening, my CYA was near Zero. When I get to where i want, right back to Clorox until 70 degree water - then life kicks in with the SWG where all I need to do is drop a cup of muriatic acid in about once a week, clean the pool once a week and drink beer while watching everyone else swim ALL SUMMER! Who wouldn't want a pool. Everyone reading this, if you are spending a LOT of time and a LOT of money balancing a pool, you aren't following much of this site's advice.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
