Thread: Difficulty with Vacuuming
    I have a 15ft. AG Intex metal frame pool. I've purchased the Krystal Clear 14in sand filter and the salt water system. I've got the water pretty clear in just a couple of days, but am left with tons of aglea on the bottom. I have an Aqua Chem vacuum head and hose that I was able to use with the old pump and filter, but can't figure out how to use it with the new sand pump. There has got to be an obvious solution that I'm missing. Any help is appreciated!
    22,551
    Re: Difficulty with Vacuuming
    You should be able to remove the screen from the skimmer and insert the vacuum hose there and get it to work. Be sure to fill the hose with water before hooking it up.
