Results 1 to 7 of 7
Thread: Starite Max-E Therm NG 400
    lioness8674's Avatar
    Sep 2011
    Lake Forest, CA
    13
    Our heater has been having a couple issues:
    1. The panel buttons are not working like they are supposed to, all the lights work, but when you push the buttons you have to push, push, push to get the thing to turn on or off and to change the temperature
    Does this mean replace the control board and the membrane or one or the other - is this something joe schmoe can do or should I have the pool guy come out and do it for $80 a hour?
    2. The other problem I am having is that when the heater does come on, it rattles and shakes the whole setup - kinda scary standing next to it. I had someone tell me it was the thermistor, another person told me it was the whole manifold kit that needed replacing. Again - is this something we can do ourselves or should we pay someone to do it for us?
    Thanks in Advance for your help!
    Finished build 4/12/12 Central MD- IG Concrete 48x26 Lazy L
    35,000 gallons, 3.5'-8.5' with diving platform and sheer decent.
    Jan 2011
    153
    Re: Starite Max-E Therm NG 400
    More the likely the shaking and bouncing is due to the internal by-pass is bad. It should get worse if you have a spa and put it in spa mode.. It's a strong chance the board needs to be replaced. Also $80.00 an hr is not a bad price at all.
    Sep 2011
    Lake Forest, CA
    13
    We only use the heater for the spa, it's in ground. Also, the guy that we had come out a couple years ago told us that our gas meter was too small for the heater - would this be causing any of these problems?
    Forgot to say our heater is at least 6 years old.
    Sep 2011
    Lake Forest, CA
    13
    Keven - would that be the Bypass Valve Kit? Is that a user friendly replacement? Al the schematics say not shown...
    Sep 2011
    Lake Forest, CA
    13
    Keven-
    Reading up about the Bypass, it says the bumping is caused by boiling in the heat exchanger. This bumping occurs right after the heater turns on - is this the same thing?
    Jan 2011
    153
    Yes that's the samething. Replaceing the bypass is very easy to do.. First you will undo the plumbing from the header, then unplug the wire from the side of the header, undo all the bolts and pull the header off, I take the thermister off also, once you have the header in your hand pull the cover off and you will see the by-pass inside... Sta-rite even supplies good instructions with all parts.
    Sep 2011
    Lake Forest, CA
    13
    Will order the part, and let you know how it goes - thanks!!
