Thread: How long does it take to raise PH
    Mar 2012
    Northern California
    59
    I have been working on getting my TA and PH down. I started at 300 TA and 8.0 ph. After adding 8 gallons of acid over the past week, I'm currently at 180 TA and 6.8 ph. I started the water aeration treatment today to help bring the ph back up so I can add more acid. How long does it generally take to raise the ph a full point?
    32,000 Gallon Plaster Pool
    Hayward Aqua Plus 40k Gallon Chlorine Generator w/ Controls PL-PLUS
    Pentair IntelliFlo Variable Speed Pump
    Polaris 3900 Sport Automatic Pool Cleaner
    Polaris 3/4 hp Booster Pump
    Pentair/PacFab Nautilus D.E. Filter 48 Sq Ft
    Re: How long does it take to raise PH
    It varies quite a bit, anywhere from hours to weeks, depending on your TA level, water temperature, and the amount of aeration you can produce. Higher TA levels raise the PH more quickly, so it will slow down as you proceed.
