Thread: OK to run generator in cold water?
    Apr 2009
    Burlington, ON, Canada
    344
    I know the low salt light will come on if the water drops below 65f in my system (Zodiac Duoclear 130 (mineral cartridge removed!!)) even if there is the correct amount of salt. Is it OK to keep the system running with water below 65 or will the cold water affect the process that produces the chlorine and/or damage the system?
    Thanks.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    38,281
    Re: OK to run generator in cold water?
    I think most SWG have a temp switch and will not run if the water is too cold. If it runs, then I can not imagine why it would hurt anything.
    I believe it only shuts off the chlorine generator. The filtration pump should still run. In fact, most year-round pools have freeze protection where if the air temperature drops below 33 deg f (or whatever the setpoint), the pump will turn on to prevent burst pipes.
    In other words, the generator will shut off automatically, and you can keep running everything like normal without problems.
