Results 1 to 13 of 13
Thread: Algae in the filter
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    Algae in the filter
    Hello Guys
    My name is Kris and I'm new to this forum.
    I received a water filtration pump from my uncle. The pump is Hayward Model #EC-30. He told me to open the pump and wash the cartridges. But when I open it these "sticks" have mold all over them. Is there a way to clean them? New ones cost over $200 and I'm able to purchase them right now.
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Algae in the filter
    Hi, welcome to TFP! The Hayward EC 30 is a DE filter, it does not have a cartridge, but uses long flexible "tubes or fingers" to hold the DE. Debris sticks to the DE as it passes through the filter. Have you hosed off the tubes? After hosing off the tubes soak them in a solution of 1 cup laundry detergent in a large, clean trash can (30 gallon can) filled with water. Let it soak overnight and then hose the tubes off well to get rid of all the soap.
    Love TFP? Become a
    TFP Supporter!
    Pysiek's Avatar
    Apr 2012
    419
    Yes you're right. The filter have tubes. My uncle wasn't running the filter for couple seasons. Do you recommend to do some kind of clean up before I will run the pump for the first time?
    30,415
    What kind of pool do you have?
    How big is it?
    How were you filtering it before?
    We need you to tell us a lot more about your pool before we can offer really accurate advice.
    How does your water look?
    The cleaning zea3 recommended, hose off and then soak in water with detergent in it, (and rinse again before using), should take care of it. The chlorine in the pool water will sterilize anything that survives the cleaning.
    Pysiek's Avatar
    Apr 2012
    419
    That's the answer I was looking for.
    My pool is the cheap above ground Intex 18' dia. framed pool. I remove it and store it in the basement every winter. Before I have used the stock filter which is pain in the butt. Very small and weak.
    Mar 2012
    Amarillo, Texas
    341
    Ha ha. We all replace the intex filters at some point. For me it was poor water circulation and running to the store to buy replacement filters. But keep it as a back up! I don't know how many times we've used it for other projects (i.e. for cleaning out a pond in our yard, etc). I figure if it breaks its no harm/no foul and I haven't lost any money since I think it was a POJ to begin with.
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    Pysiek's Avatar
    Apr 2012
    419
    mpacheco72 you're totally right . I have to go to the store and buy 6 pack of those filters every week
    Mar 2012
    Amarillo, Texas
    341
    You'll enjoy your DE filter. And it feels less wasteful to know you're not throwing all those paper filters into the earth.
    18'x48" AG
    Hard Plumbed
    Pysiek's Avatar
    Apr 2012
    419
    I hope I will. Do you think I should keep the pump it comes with or I should replace it with better one?
    Mar 2012
    Amarillo, Texas
    341
    I would just keep the one it comes with. It's just a backup pump for whatever you may need it for. This year I had the greenest pool ever and I used my sand pump and my intex pump at the same time to clear it faster. Don't know if it helped but it seemed to!
    18'x48" AG
    Hard Plumbed
    Pysiek's Avatar
    Apr 2012
    419
    Guys I found this link http://www.ehow.com/how_4810795_clea...l-filters.html . They say I should use muriatic acid to clean the filter. Did any of you ever used that?
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    You should soak them in water with dishwasher detergent after hosing them off. You do not want to use acid on them until after you've cleaned them thoroughly w/ dw detergent, or TSP.
    Read Waste's thread on DE Filters.
