Results 1 to 10 of 10
Thread: Pentair Kreepy Krauly Sand Shark
    Anyone have any experience or thoughts in regards to the sand shark? In theory it looks promising but for some reason not much talk about it. It has no wheels to wear out and from looking at the parts diagram there are really not many parts which should wear. It has no wheels to wear I am either looking to purchase this or a suction side the pool cleaner any advice?
    Aug 2011
    El Paso, TX
    25
    Re: Pentair Kreepy Krauly Sand Shark
    I have one and works great. I would say it cuts down on my manual vacuuming by at least 50%. Definitely recommend if you don't have an automatic vacuum.
    IG plaster; 32x16x3-5 ft. w overflow spa; ~15k gals; 2 hp Pentair pump; 120 gpm Pentair DE filter; Pentair heater
    Would the sand shark be a better gamble then getting a poolvergnuegen? will the scrubbers on bottom of sand shark wear? Too me it looks like the sand shark has very few moving parts less then the poolvergnugen what do you thing? I am upgrading from a regular kreepy krauly which keeps getting stuck on main drain or ladder getting tired of babysitting it
    Aug 2011
    El Paso, TX
    25
    The scrubbers look good on mine after 1 yr of constant (>4hrs/day) use. I guess the scrubbers can wearout eventually, but mine haven't. I'm not familiar with the other product.
    Does the sand shark climb walls? My Kreely Krauly Classic from childhood would climb and clean the walls. I am considering a new vacuum for my new home, but it did not look like the sand shark was capable of climbing walls or going over uneven surface changes gracefully.
    Or am I wrong?
    16,000 gal in-ground
    Pump: Hayward C48K2N143 1HP 230V
    Filter: DE Triton Nautilus FNS-36
    Aug 2011
    El Paso, TX
    25
    Sometimes it does, but not usually.
    Aug 2011
    El Paso, TX
    25
    Like this (ignore leaves, very windy last night)...
    Feb 2012
    Lancaster, PA
    112
    Does anyone know if the Sand Shark is quieter than the Kreepy Krauly? I was considering the Kreepy Krauly Classic until I watched a video of it in action, and that constant "clicking" sound it was making would probably drive me nuts! So I am probably taking that one out of the picture, and am considering maybe the Sand Shark instead. Is it fairly quiet?
    16 x 32 vinyl In-ground Lagoon; Shallow pool 3' to 5'; Buddy Seat; IntelliBrite 5g LED; Pool Pilor Digital SWG, Pentair Clean & Clear Plus 320; Pentair Intelliflo VS + SVRS; Pentair Sand Shark. My Construction Thread - Spring 2012
    No clicking sound while in the water. I was told by the pool store owner that sold mine that you shouldn't have it moving faster than about 3 ft/min to preserve pad life.
    It's a bit of a balancing act getting the pump speed and port flows correct, and it doesn't really get more than half the wall before turning around. I haven't owned any other models to make a comparison.
    38,000 gal. IG gunite pool -- 20 x 40
    Pentair IntelliFlow VS Pump
    Pentair FNS 48 sf DE Filter
    Sand Shark suction side cleaner
    Hi,
    just wanted to add to this.. not sure if you have purchased a cleaner yet, but I went for the poolvergnuegen "pool cleaner".
    so far this thing rocks. I've had it about 3 months. It's connected to my skimmer with the same plate I used for my vacuum.
    The only caveat is that it uses the skimmer port so you don't get any skimming action.
    my resolve? I bought a pool devil.
    The combination of those two have kept my pool spotless for the most part. I swear since I put them in, I have not touched my pool except to brush the walls one time for preventive maintenance... and used the net to fish out a mouse
    Another suggestion, use panty hose for the 'socks' of the pool devil. The ones that come with it don't last long at all.
    I couldnt' be happier. all for $450 total.
    hth
