Results 1 to 17 of 17
Thread: Jandy deck jet versus mini jet
    Jun 2011
    Fullerton, CA
    31
    We are planning to add jets along the back of the pool and also to the baja reef. I'm looking at the Jandy deck jets and mini jets, but have a hard time find what the difference is between these two jets. Anyone knows?
    Thanks.
    Feb 2012
    Phoenix, AZ
    728
    Re: Jandy deck jet versus mini jet
    Hey pumpkineater, welcome to TFP!
    MiniJet
    project a stream at a 45 degree angle
    projects water up to 13 feet
    can be mounted on deck OR under coping
    Deck Jets
    nozzles can be adjusted 360 degrees
    zodiac does not list water projection, but I have seen them much longer than 13 feet
    Jun 2011
    Fullerton, CA
    31
    Blakej, thanks for the welcome! This site is very informative and helpful to not so savvy home owners.
    Is there a preference when to use a deck jet versus a mini jet? Attached is a drawing of our pool remodel. The red dots indicate a jet.
    Feb 2012
    Phoenix, AZ
    728
    I would recommend Deck Jets because of their versatility. The option to rotate the nozzle will give you a chance to try different stream positions. Just my opinion though..I am curious to see what others have to say!
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I agree; being able to move them around sounds fun.
    Jun 2011
    Fullerton, CA
    31
    Thanks. I'd appreciate the feedback. I'll be looking more closely at the deck jets.
    I've seen the Jandy deck jets being popular. Is that the best quality jet, or should I look at other brands?
    I have been looking into these as I would like to incorporate them into our new deck, it seems as the jandy deck jets are the more cost affective option but still seem to be of good quality.
    I have been seeing them run ~360 or so for set of 4
    I have seen others run upwards of ~700 +
    They have some wicked led options that change colors of the stream but your gonna pay for the wicked option
    I have my wife sold on the normal deck jets but still need to offer up unborn children for the led option lol!
    18' x 33' Aqua leader AGP (~19k gal) w/hayward swimpro voyager cartridge filter and 2hp hayward pump.
    8 Gal LQ, hayward heater.
    Oct 2009
    3,899
    If you're interested in the LED jets, spillmar has some pictures in his build thread...
    pool-build-california-dreaming-still-dreaming-t20686-460.html
    Jun 2011
    Fullerton, CA
    31
    Thank you all.
    Has anyone used the brass jets sold by Deck Jets? If so, how do they compare to the Jandy deck jets. Here is a link for the brass jets:
    http://www.deckjets.com/buy.php
    Jun 2011
    Fullerton, CA
    31
    Re: Jandy deck jet versus mini jet versus brass jet
    Any feedback of how brass jet similar to this works out, is appreciated. Especially when compared to Jandy deck jets. Any pros and cons?
    Dec 2010
    San Diego, CA
    1,137
    It seems like some deck jets create smooth streams of water and others are really broken up more like water out of a hose. Is it the jet or the water pressure or a combination of both that create that smooth tube like stream of water?
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    22,542
    It's not only the jets but the piping leading up to the jets that create laminar flow (smooth tube like stream). The pressure affects it a little but the design and manufacture of the jets make the biggest difference.
    Dec 2010
    San Diego, CA
    1,137
    Thanks Bama
    Jun 2011
    Fullerton, CA
    31
    Not sure if my question is answered, but I do appreciate all the responses.
    Thank you.
    Oct 2009
    3,899
    I haven't seen the brass ones before. They must not be that common, which would make me wary.
    What's interesting is the jet one a couple of these models use quick connect's, us fish geek's use those quick connects on the returns on fish tanks, if time allows this weekend I am going to connect one of mine off the fish tank and connect it to a garden hose to see how the stream looks, those quick connects are alot less expensive than the deck jets.
    If it works I will post a thread on it
    Jun 2011
    Fullerton, CA
    31
    One reason that I'm looking at the brass jets, besides the longevity, is that it is possible to get them cheaper than the Jandy jets. But I'm also want to make sure performance is not going to be a problem. As I haven't come across anyone using them, I'm keep looking for information. It might just be that they are not known to the majority of pool owners.
