Re: Feeling a shock when touching ground
[Moved back to original thread - Mod]
I don't want to get the threads confused either. I now understand that we are not bonded properly as you describe. I also understand that our county doesn't require it so our pb is off the hook. What Deb explained about her daughter sitting on the deck and putting her legs in the water is exactly what happened to me yesterday. I think it was you that posted last about finding a way to get a copper wire into the water system somehow to create that equiponential bond (I'm reading and learning trust me).
On the other side of the issue is our power company did indeed admit that there was a stray voltage issue. Unfortunately they just don't seem to care. Like deb, when the power company shut the power to our off to our property entirely not only was there still measurable voltage between pool and deck but the electrician said it increased.
The problem does (I understand now) seem to be the lack of bonding of the cement with the whole system. I get it now. Stray voltage is bad but not noticeable with proper bonding. Let me know if I'm wrong.
On the other side the power company in my case did indeed admit a stray
