Results 1 to 13 of 13
Thread: Use Miami well water to fill pool?
    May 2011
    Miami, FL
    271
    Hello
    Yes, it sounds crazy and perhaps is. But I ask other Miami forum members if anyone has used well water to fill up their pool? Will my chemicals go totally wack?
    Thanks
    16,900 gallon inground pool (16x30 with spa bench)
    Sta-rite cartridge filter
    Diamondbrite surface, redone in 2017.
    1.5hp Hayward Super Pump
    Hayward Navigator Pro suction cleaner with V-flex kit
    30,400
    Re: Use Miami well water to fill pool?
    1, Why do you want to use it? It cannot be as good for your pool as municipal water
    2. To have any legitimate opinion, you would have to post test results so we could see what's in it, if anything.
    3. Generally speaking, well water can cause unnecessary problems in your pool. If it is easy to avoid them by using municipal water, then that's your best bet.
    May 2011
    Miami, FL
    271
    in Miami, we are charged for water and sewer for all water consumed. So all gallons going into the pool gets double billed. By using well water, I avoid that. But, if the chemical damage may be worse, then I remain skeptical.
    38,235
    Many water companies will adjust your bill if you call them and tell them you are filling a swimming pool. They should be able to see your abnormal usage in a given month and not charge you the sewer portion for the pool fill. This seems pretty common on the boards, but YMMV.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    I've never heard of a utility authority which would not compensate the sewage charge for filling a pool. Technically, it is unlawful for them to charge for services they have not provided, nor assess you for services you have not used. Call them and let them know what you are doing - they have already done this before for a *lot* of pools in Miami.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,049
    In Jacksonville they will not credit you the sewer bills. They want you to buy another meter and charge you for water usage. We have one that we uses for irrigation, pool, washing cars, etc. The cost of this meter was $600, however I heard that it is changed to $1200. Sounds expensive but it will pay back for itself.
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    I've heard several muni's preferring of dual-metering, and I can see the potential, but for me, there is an issue of charging a taxpayer for services not provided. I wonder what the local small-claims court would have to say if someone took them to task for it?
    May 2011
    South Texas
    23
    we used our well water in South Texas (no choice where we are) and have not had a problem getting our water balanced, but I suppose it depends on what is actually in your water. I'd say have it tested and then decide.
    Assisted install/DIY project 2012: 15,000 gallon ,15x34x6 Fiji by Viking fiberglass pools with Azure blue diamond finish, 1 1/2 hp dual speed pump, 30" Hayward Sand filter, inline tablet Chlorinator (at least until I decide on a SWG- this is ALL new to me)
    Prav's Avatar
    Nov 2010
    Miami, FL
    94
    The compensating for sewer charges is for limited circumstances (e.g., a complete fill of the pool) and only once/twice a year. I think what the OP is referring to is when you "top off" the pool for evaporation.
    I'm in MIA too, and I had the same thought a few weeks ago. If I get around to putting sprinklers, I'd do it on a well. It's "free" water, right? It's just not potable/drinkable, but it can be used for grass and other outside uses, no? So, if it has too much in terms of metals (iron) etc, it may not be quite right for pool. High contaminants should not be an issue other than increased CL consumption.
    14'x30' (est. 14K gal) w/spillover spa (est. 500 gal) - 1995 // Diamond Brite Blue Quartz - 2006
    Hayward SwimPure Plus T-15 - 2013 // Zodiac MX-8 - 2013
    Plain ol' Intermatic mechanical timer // Pump: 1 HP Pentair SuperFlo - 2012
    Filter: Hayward C17502(S) Cartridge Filter - 2011 // Heat Pump: Sunrunner/Aquapro 1300 (127K BTU) - 2011
    We filled with well water and have had no problem with any metals. I did test before fill though to make sure...
    Chris
    http://www.circledspecialties.com
    44,000 IG Salt Pool - Pentair VF, Quad 100, Polaris 280, IC60, 400 Mater Temp
    Nov 2011
    Tampa Bay FL
    58
    Quote Originally Posted by Ohm_Boy
    Pasco County does not compensate. I called them to inform that I was going to fill a pool and was told that I would be charged anyway.
    15x34 in ground, 16.5K gallons, Emerald Isle pebble finishing
    Pentair IntelliFlow VS-3050 pump
    Pentair Quad D.E. filter
    Pentair IntelliChlor
    Pentair IntelliBrite 5g LED light
    Pentair Great White Vacuum cleaner
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    I'll be quick to point out that i _AM_ an idiot, but I don't see how that is legal. I concede though, that I was certainly wrong, and there seem to be many places that don't compensate.
    Nov 2011
    Tampa Bay FL
    58
    Several people mentioned what you said and even some county employees agree, but the county is not that flexible. They will give a break if you pipe breaks, but for a pool fill there is no common sense....
