Results 1 to 9 of 9
Thread: Plastic deck ladder problem
    Trying to install the ladder that came with my hundred dollar pool, and the legs that attach to the deck slide up and down into the sleeve of the ladder.
    Are you suppose to put two screws in those indents in the plastic to stop it from sliding?
    I got all the instructions for every thing except the ladder... Of course it was the only thing I need the instructions for!
    Rob B
    My $100 pool finally died after 6 years.
    Totally got our monies worth!
    Butterfly made me do it...
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: Plastic deck ladder problem
    Kinda looks like there should be a platform right about where those holes are. Can you get a pic from just a bit further back to show more ladder?
    Here ya go! I pulled it out of the pool though... Found model #6100 stamped on the side, gonna try and find that.
    Rob B
    Yup, it's a Confer model #6100, says to put in 4 #10 x 1-1/4" screws when you get the height adjusted.
    Thanks ohm boy!
    Rob B
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Hey - don't thank me, you posed the question, did all the legwork, found the answer, and let everyone else know what you found. I din' do nuttin.
    You started to help! That's worth a thanks!
    Rob B
    I do have to get that paint off the ladder though... Know any tricks without scratching the plastic too bad?
    Rob B
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Goo-Gone.
    That stuff works on paint too? I'll give it a shot!
    Rob B
