Thread: rust on wall
    Mar 2012
    NC
    138
    rust on wall
    Okay, and I know this is a lot of judgement and such, but I have bought an above ground pool, and honestly went as cheap as I could get and the pool has some rust. My plan is to reinforce the wall at the bottom, where the rust is, and coat it with bedliner before I bury it. How much rust is too much rust and what kind of problems can I really run into? I thought I was in the clear and it was manageable until I read on here about an aneurysm. It isnt so bad that the wall is structurally unsound (in my opinion), but it is rusted and cracked at some spots at the bottom. 1' of the pool is going to be buried in the ground, and the rest surrounded by a deck, which is why cosmetics were not an issue. Some of the bottom rails are rusted too, which I am getting replacements for, but I dont want to the pool to just collapse because I was wrong in my judgement.
    33' Seaspray Aegean II - 6' Deep End
    28K Gallons
    2" Hard Pipe Plumbing
    Hayward S244T 300 lb. Sand Filter
    1 HP - 2 speed - Powerflo Matrix Pump
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: rust on wall
    If it's rusted through I would recommend pop riveting aluminum plate over the infected areas. The bed liner sounds like a good idea too.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Mar 2012
    NC
    138
    Re: rust on wall
    That was my plan. Thanks for a little confirmation.
    I was actually just going to screw it on and cover the heads with duct
    Tape. The rust is on the bottom 8" of wall.
    28K Gallons
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: rust on wall
    I use pop rivets as they are the closest to flush you can get in terms of screws etc.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Re: rust on wall
    You'll probably be fine with the reinforcement, also the foot recessed underground will be supported by the backfill. To help treat the rust I've used 2 products. Os-Phos, its a mixture with phosphuric acid and turns rust into metal, it used on cars and gas tanks. The other is rustoleum cold galvenizing zinc compound. Label says its 97% zinc, sprays on, leaves a primer gray finish, bonds good to rust. I've been repainting my frame with ""valspar anti-rust armour oil based enamel gloss" and have been happy with the outcome.
    Years ago I painted my off-road chevy with bedliner, it did a great job. I got sideswiped by a cadillac, their paint was rubbed all across the side of my truck, scrubbed right off at the carwash. It took months to sell, everyone was afraid of the paint job!
    When the only tool you have is a hammer everything starts looking like a nail.
    Doughboy 16x24 "Aboveground Inground" in progress...
    Mar 2012
    NC
    138
    Re: rust on wall
    Thanks guys, some great ideas coming here.
    28K Gallons
