Thread: Raising Alkalinity
    Apr 2011
    Brookeland, Texas
    89
    Raising Alkalinity
    My numbers are:
    TC - 4.5
    CC - 0
    PH - 7.8
    CH - 250
    TA - 30
    Last year my TA was very high with my fill water so while controling my rising PH due to new plaster with MA, it also brought my TA down. Now the PH still continues to creep up and my TA is 30 due to acid additions. If I want to raise my TA back up to around 70 or 80. Will adding Baking soda just be counter productive to my PH where I will have to add more acid to keep it in check?
    12k gal. Free form 14' x 28' IG gunite, 8' raised spa, Hayward T15 SWG, Hayward Ecostar VS pump, Hayward Super II pump, Booster pump, Polaris 280, Hayward DE 7220 filter, 400k Btu heater, Color logic LED lights. Pro Logic controller with remote.
    30,432
    Re: Raising Alkalinity
    Easily the most misunderstood parameters we discuss, TA and pH can be controlled separately and, for most of us, should be.
    Raise pH - Borax
    Raise TA - Baking Soda
    Lower pH - muriatic acid
    Lower TA - aeration and muriatic
    There are other ways to think about it but these simple ideas work. Raise your TA with baking soda....it will have very little effect on your pH.
    Rising pH is a fact of life in most pools. It is controllable but most of us have to use acid to lower it down from time to time. Of course your TA goes down with it but can be raised (without changing pH much) using Baking soda.
    22,553
    You're gonna see-saw a little for a while until your new plaster job settles down but it shouldn't be too much of a job. I'd raise the TA up to about 60 and see if that works. If you raise it too high it'll definitely affect your pH and you'll have a greater job chasing it.
