Results 1 to 20 of 20
Thread: keeping steps clean??
    Murfreesboro, TN
    92
    we have ig 8' white steps that keep fine silt dirt on them. the polaris 280 does not do steps i guess.
    i had the same problem with the last pool we had (same kind of steps, same cleaner)
    we have a return jet on each side of the steps.
    Has anyone had any success positioning these jets in a fashion that cuts down on the step dirt?
    Maybe circulate the water in and out or use the jets as a barrier to keep stuff out of the step region.
    Any different jet inserts make a difference.
    or just brush the steps everyday?
    Cal C.
    20k ig vl, hayward 2sp Tristar, hayward pro series sand filter, ecommand 4 with aqua connect, hayward heat pump, polaris 280 cleaner, TF-100.
    30,426
    My cleaner doesn't do steps, either. I've had a little success by directing the jets and I find it helps but doesn't cure. I brush the steps every other day and they stay okay but only okay.
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    I've got the exact same situation, including the same cleaner accept my jets are not near the step.
    Any chance there is new construction going on around you?
    We live in a new section of our neighborhood and there are still homes going up around us which seems to keep dirt in the air - street sweepers, etd.
    I have noticed though that th further the construction moves from us, the less of that silt I find on the swim out and steps. I hope that when the construction is done, the dirt will be gone.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Arizona
    924
    My steps and the loveseat are always in need of brushing.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Nokesville, VA
    18
    We live in the woods, so our steps always need brushing, too! Must just be one of those "perks" of being a pool owner!
    42,525 gallon IG gunite pool with DE filter and spill-over hot tub.
    TarheelPool's Avatar
    Mar 2007
    Burlington, NC
    86
    I have the same issue but just keep it clean by brushing regularly. I actually like working around the pool so it just gives me an excuse to be out there.
    Kevin
    Foxx 18 x 36 IG Vinyl
    TR60 Sand Filter, Pentair Whisperflow 1hp, 2" Plumbing
    Blue Pearl robotic cleaner
    Burlington, North Carolina
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    Cal,
    I had.... had the same issue. Come to find out that it was my flagstone settling in. To fix the problem, I lightly sanded the stones (coping) and then applied a sealer to them. They no longer have that gritty feeling and none of the junk is getting in my pool now. I did a thorough vacuuming after I had finished the sealer. Hope that helps.
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    RAA's Avatar
    Mar 2007
    The Woodlands, TX
    46
    Quote Originally Posted by divnkd101
    Cal,
    divnkd101 ,
    This is exactly my problem too, the flagstone feels gritty and when i hose it off, i can see that red dust going into the pool, i'm sure the salt water doesnt help it..... what grit did you use to sand and what sealer did you use?
    -Rick
    ~15k Gal IG
    Gunite/White plaster
    AquaLogic PS-8 w/SWG
    divnkd101's Avatar
    Mar 2007
    587
    I went to Lowes and bought a bag full of the foam sanding blocks. I did just a real light sanding just to clear any loose grit off of the top. Hosed it down when finished, let it dry. Then I applied "Diamond Bright" Deck Sealer with my 2 gallon bug sprayer. I direct you to THIS POST for details of the sealer. If you need anything else, let me know.
    MIKE
    RAA's Avatar
    Mar 2007
    The Woodlands, TX
    46
    I'll continue this discussion on the other Thread
    -Rick
    ~15k Gal IG
    Valley Forge, PA
    32
    Same deal here
    I am in the Valley Forge area in an established community. My steps and swim out accumulate fine dirt and need to be brushed every other day or so to keep the dirt off. As someone else pointed out, it does give you a reason to be out by the pool.
    30K gal in ground shotcrete pool with Sunstone Select finish
    Attached raised spa with spillway
    DE filter, 400K btu heater
    Ray-Vac cleaner - replaced with Letro Legend 2
    Use BBB methods
    Mar 2007
    Houston, TX
    167
    I would add that you might want to try using "skimmer socks" if you arent already. I was amazed at how much fine dirt I am now trapping at my skimmers. I'm sure there are several brands available. The ones I found are made by BioGuard. They are listed at the bottom of this link. Skim Mor
    I actually just purchased skimmer socks yesterday - I'm amazed how dirty the first one is already (thought the pool was sparkling)
    SW Connecticut
    18,000 Gal Freeform
    Murfreesboro, TN
    92
    I have a set of 6.......they do help and boy, they get dirty!!
    Cal C.
    Arizona
    924
    I just bought some a couple of weeks ago. They work great!
    Buggs
    Iowa
    38
    My steps get dirty also but not nearly as bad ever since I started adding DE to my sand filter. This really helps to pick up the fine dirt and silt.
    Mar 2007
    Houston, TX
    167
    Quote Originally Posted by brittmer
    Good reminder. My Pentair Cartridge manual says to add 3lbs DE to enhance filtration. The only problem is I can only find it in 25lb quantities. That much would last me for years.
    Warning!!!!
    Please don't go and dump 3# of DE into a sand filter!!! While DE is a great addition, most folks find that they need less than a cup!
    Add the DE slowly through the skimmer, a little at a time, over the course of (several hours, maybe?) and when you have achieved a 1psi rise in your filter, STOP! you have added enough! When you backwash, you will have to add the DE again.
    I was also under the impression that DE clogged cartridge filters and should not be used??
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    25 lbs does seem like a waste, but it doesn't cost much. Leslies web site lists 25 lbs for $14. As long as you have somewhere to put it why not splurge. I have heard stories of 10 lb boxes but I never found anyone who sells them.
  20. Back To Top    #20
    Mar 2007
    Houston, TX
    167
    Quote Originally Posted by The Mermaid Queen
    Warning!!!!
    Yep never said to add 3# to a sand filter.
    Here is a snip from page 4 of the Pentair Clean & Clear Plus Cartridge Filters Owner's Manual. These are Pentair's recommendations. I dont know if their cartridges are unique as compared to other mfr or not.
