Results 1 to 15 of 15
Thread: Ordered IC40, Now what
    Jun 2011
    San Diego California
    88
    I just came across a deal on ebay too good to pass up (IC40 and Power center for $550 new and delivered). Still one left if anyone's looking for the system.
    I was considering getting this setup, but never really looked into what's invovled in the setup after the units installed. Given I'm installing a new Intelliflo, I figured I should grab the deal and setup everything at once.
    Is there a good thread on setting up the Pentair Intellichlor systems? It will just be the VS with SWG, as I donlt have any automation system yet. I didn't see a sticky in this SWG forum, but figured I'd ask for suggestions.
    IG, 13,000 gal, concrete, DE, VS Intelliflo Pump, Intellichlor SWG
    San Diego, Ca.
    22,551
    Re: Ordered IC40, Now what
    It's just a matter of plumbing it in and hooking it up according to the manual. Once you get it you'll have the manual to go by.
    Jun 2011
    88
    Coupel questions after a quick review of the manual.
    - Can the SWG unit be mounted vertical, or does it half to be horizontal?
    - The manual states it is installed after the heater. Is this absolutley necessary? My problem is the plumbing comes out of the heater, straight into a valve, and then two vertical lines into the pad. There is just no room or place to insert the Intellichlor. For this to be installed after the heater, I'd need to run lines out and away from teh heater and then back, which is possible, but a real PITA.
    San Diego, Ca.
    22,551
    Post a pic of the pad and someone will have a suggestion. It's amazing what some people can figure out.
    Feb 2012
    Phoenix, AZ
    728
    Quote Originally Posted by markmac
    Yes, you can mount the IC40 vertically. You just need to make sure you have enough head to keep water moving effectively through the cell
    You really should not install a SWG in line before a heater. You want your SWG right before the water returns to the pool. Even though it might be more of a PITA to do the plumbing this way, it will you save you in the long run. You don't want to prematurely wear out your heater or any other equipment!
    Jun 2011
    88
    Quote Originally Posted by blakej
    My heater is basically junk, and only worked twice since I purchased the house/pool last year.
    San Diego, Ca.
    Jun 2011
    88
    Here are a few pics of the items I inherited buying the house. I have an INtelliFlo VS and now Intellichlor to install (new heater hopefully next year). As I stated, the issue I see is the return from the heater is straght into the valve for the spa/pool return line. Best I can see, I need to shorten those two, and make a loop for the IntelliChlor to fit in before the valve (hence my question about mounting it vertical. However if I mount it vertical, it won't have the sugegsted 12-28" of straight pipe before the SWG. Since the heater is basically junk, maybe I just bypass it all together.
    I'd welcome anyone with ideas.
    [attachment=2:1pa4idoi]Pic1.jpg[/attachment:1pa4idoi]
    [attachment=1:1pa4idoi]Pic3.jpg[/attachment:1pa4idoi]
    [attachment=0:1pa4idoi]Pic5.jpg[/attachment:1pa4idoi]
    San Diego, Ca.
    If the heater is really junk might be a good time to yank it and install the ic40
    Seems like you got a smok'n deal on that, I checked eBay but didn't see any in that price range, if by chance they are still available maybe you can pm me a link.
    Thanks
    Chris
    18' x 33' Aqua leader AGP (~19k gal) w/hayward swimpro voyager cartridge filter and 2hp hayward pump.
    8 Gal LQ, hayward heater.
    Jun 2011
    88
    Without an automation system/controller, am I understanding it correclty that the Intellichlor would be powered 24/7 and it senses when there is enough flow to generate chlorine? I am planning to only run my pump 10-12h on a very low speed (~25gpm) and then twice a day at a higher speed for skimming.
    I have to say that after purchasing the intelliflo and Intellichlor in the last couple weeks, Pentair's manuals are really, really sad.
    San Diego, Ca.
    When you don't have an automation system you normally wire the IC40 to the output of the timer, so it only gets power when the pump is running.
    Jun 2011
    88
    Where I have the VS that runs its own schedule I basically have to put the VS and IC on a timer, or run the pump 24h? Or is the IC smart enough to know when it should run and when it shouldn't (even though it has power24h).
    If a timer is the answer, amd I better off just looking for an automation system?
    San Diego, Ca.
    susa's Avatar
    Oct 2010
    Deep South
    578
    Another alternative is here.
    Jun 2011
    88
    Quote Originally Posted by susa
    Susa, Thanks. I came across that last night when reading more posts about SWG's. I think that is likely the answer to what I'll need to do. Reading the post, I'll likely have to go down the 220V setup as it woudl require a seperate circuit setup also to do 110V.
    Mark
    San Diego, Ca.
    Jul 2014
    Thousand Oaks CA
    9
    Susa - do you have photos that still work? It seems they have moved or deleted and don't show up. Thanks!
    Jun 2011
    Long Beach, CA
    2,790
    Since you are not using the heater and are planning on replacing it, remove it now and install the SWG in its place. When you install the new heater make sure the SWG is installed after the heater.
