Results 1 to 8 of 8
Thread: 3800 ppm...Leave it or drain it?
    Mar 2012
    Northern California
    59
    I installed a new Hayward salt system on my pool last week and must have miscalculated the amount of salt to add. In any case, my salt sensor is telling me that my salt level is 3,800 ppm. Should I just leave it and let it come down over time, or should I drain some of the water and add fresh water to bring the level down?
    32,000 Gallon Plaster Pool
    Hayward Aqua Plus 40k Gallon Chlorine Generator w/ Controls PL-PLUS
    Pentair IntelliFlo Variable Speed Pump
    Polaris 3900 Sport Automatic Pool Cleaner
    Polaris 3/4 hp Booster Pump
    Pentair/PacFab Nautilus D.E. Filter 48 Sq Ft
    30,431
    Re: 3800 ppm...Leave it or drain it?
    If you are producing chlorine, I would leave it.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    3400 is the recomended high limit, but the readings on the panel are notoriously inaccurate. Generally it's better to have the level on the high side than low, so 3800 should be fine.
    chiefwej
    Mar 2012
    Northern California
    59
    I had the water tested at a local pool supply store and they got the same reading, 3800. My biggest concern is having the pool taste like salt. I've had some people tell me that anything over 3000 and you start tasting the saltiness in the water. Those of you that have salt water pools, what's your experience?
    mas985's Avatar
    Pleasanton, CA
    11,741
    My experience has been that the Goldline units are very accurate displaying salt levels. Mine matches my drop kit very closely. However, not all SWGs are accurate.
    Anyway, the high salt level is not a problem unless the unit shuts off due to high salt. The limit is actually not the salt level but the amps. If the unit exceeds 8 amps, it will shut down with a high salt warning. At that point, you will probably need to dilute the salt level. But if the unit operates without shutting down, then no harm.
    Mark
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    You can't taste salt at 3800. Your slightly above contact solution level. We don't tell people we have salt till afterwards to see there reaction! Most people no nothing about salt water pools, that is the one's that don't own them! My mother-in-law even argued with me until I showed her the salt! The most common reaction we hear is "The water is so soft, don't feel like I need to shower after we get out"! I will never go back to the old school way again! At 3800 as long as your producing CL I would leave it. Once the season gets in full swing with splash out and backwashing that will come down.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Mar 2011
    Houston, Texas
    413
    Quote Originally Posted by maxepr1
    I can taste the salt in my pool and it's at 3300 ppm. But it barely noticable and it's not a problem.
    I agree with the others that if your SWG is producing chlorine I would leave it alone. In fact, a decent rain could bring it down to below 3000. That's happened to me twice this spring.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I agree with the others. Leave it, it will come down through splash out and back washing (if you have a sand or DE filter). If it isn't broken don't mess with it.
