Thread: CYA in skimmer / Circupool SWG
    Pool School says to put CYA in a sock and then put the sock in the skimmer to dissolve. I did this and later realized in the owner's manual for my Circupool RJ45 it specifically says "DO NOT" add chemicals via skimmer (emphasis theirs). In addition, i noticed a couple times while the CYA was in the skimmer the RJ45 unit was showing a high salt reading (the warning led was lit, and the display read high salt as well).
    I doubt there was any harm done, just wanted to raise the observation for others who may have this unit and need to add CYA to get up to pool school recommended levels.
    Pentair WhisperFlo WFDS-4 - Pentair Tagelus TA 100D
    16x32 Vinyl Rectangle 3.5 to 8 ft deep - One skimmer, One dedicated suction, three returns - 2" PVC
    Poolvergnuegen Two Wheel Suction Cleaner - One Poolskim
    Inter-Fab T7 Diving Board w/Edgewater Assy - Four Pentair Deck Jets - Intermatic T10604R
    Circupool RJ45 - Taylor K-2006 Test Kit (purchased prior to learning of the TF-100, unfortunately)
    30,421
    Re: CYA in skimmer / Circupool SWG
    You did no harm to your pool or equipment
    I'm sure that manual is referring to the DIRECT addition of chemistry like MA or Chlorine into the skimmer. Putting the CYA in a sock inside the skimmer is just fine because it dissolves very slowly and there is never a big "slug" of chemistry that passes through the equipment.
    In fact, the forum finds it acceptable to directly add CYA slowly into the skimmer and allow it to be captured by the filter and slowly dissolve inside the filter. You cannot backwash during the time it is dissolving, though, and generally speaking, the sock method is still the best.
    CYA dissolves slowly enough that it doesn't have any effect on the SWG when put in the skimmer. I assume the high salt light was coincidental.
    OK, got it. Good to know. Thanks guys.
    I guess i thought the high salt light was related since it had never been on since i installed it a couple weeks ago, and the results of my last strip test was 3600 (manf recommends 3500). The light isn't on now. May just be a correlation/causation error on my part.
    Thanks again.
    The salt reading will vary just a little bit over time even if the actual level remains constant. If you are very close to the upper limit, the light will come on intermittently.
