Results 1 to 15 of 15
Thread: Intex 18'x52" filter pump upgrade question
    So I just ordered the 18ft x 52in deep round Ultra Frame Intex pool from target.com. It comes wil the weak 1500gph pump, so I also ordered the Intex 2500gph pump online separatly.
    My question is will I need to cut the pool liner to use the larger pump or does it already come with the right size adapters/holes?
    Oct 2011
    New Caney, Texas
    414
    Re: Intex 18'x52
    If it doesn't come with the same connectors there are adapters you can purchase. Also have a look at this link:http://www.troublefreepool.com/usefu...rs-t29612.html
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    May 2011
    Clearwater, FL.
    446
    Re: Intex 18'x52
    Hi Sangster and welcome to TFP!
    I posted what I did when hooking up my 1HP/22" sand filter system here in one of the links that George posted about:
    custom-pvc-pipe-adapter-for-intex-pools-t28971.html
    My posting starts at the bottom of page 1 and goes through the end of the post.
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    Re: Intex 18'x52" filter pump upgrade question
    I actually read through most of all them already but none answer my question.
    Has anyone with the 18'x52" ultra frame upgraded to the 2500gph pump? Did you have to cut?
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    Re: Intex 18'x52
    i upgraded my 16x48 to the intex sand filter and the cut outs on mine were a perfect fit. i believe everything from the 16x48 on up in size will be able to utilize the existing holes in these pools to upgrade to the intex sand filter.
    18x52'' intex AGP, 6981 gal, 2650 intex sand filter,
    thru wall skimmer, SWG, 52'' 20G overlap liner, intex pool light
    Re: Intex 18'x52
    that's well and good, but I'm not upgrading to the Intex sand filter.
    Has anyone with the 18'x52" Ultra Frame upgraded to the 2500gph pump? Did you have to cut?
    Re: Intex 18'x52
    Quote Originally Posted by Sangster
    I upgraded my 16 x 48 to a waterway 1.5 hp pump and hayward sand filter. I used these adaptor to take the place of the intex connectors, this 1.5 female thread on the inside uses common 1.5 pipe fittings that can be found at home depot,lowes, etc.
    http://www.ebay.com/itm/320612653607?ss ... 1439.l2649
    I am using high pressure hose and connectors and unions so i can disconnect it all. I have these gate valves on the pool and a 90 elbow union to hose on both the in and out.
    But it should be the same fitting if its from intex. But if its not intex products, nothing will fit intex brand stuff.
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    Re: Intex 18'x52
    i've seen some 18x52 pools that came with the 2500 gal pump on amazon.
    Re: Intex 18'x52
    Quote Originally Posted by jsf0656
    Me too, which is why i have my fingers crossed that I won't have to do any cutting for it all to fit.
    I was going to get the pool that included the pump on Amazon for $679 plus $250 shipping, but instead I spent $800 to buy the pool at target.com and the pump separate on Amazon.com.
    I hope I don't have to cut it!.
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Re: Intex 18'x52
    Sangster, The reason you are not getting a lot of answers about the 2500 pump is that when most folks upgrade their intex pump they go to pump that works for a large pool. The intex "cartridge filter pumps" are not worth the money, underpowered and underfiltered for anything bigger than 10'. I have had several different intex pumps over the years and they just do not work for a larger pool. Do yourself a favor and get a pump/filter that works for your size pool.
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    Re: Intex 18'x52
    mcoonan is right! go with the intex sand filter and you will not look back. my pool has been perfect ever since i changed over from the weak pumps that come with these pools!
    Re: Intex 18'x52
    I had a 2500 gph Intex on an 18' x 48" Metal Frame pool for quite a while and it worked just fine. I bought the pool used though, so I'm not sure if the original owner had to cut it or not. This one only cost me $94, and since it worked for me before, I'm going to give it a try. If it doesn't for some reason, then I'll upgrade at that point. I suspect it will be just fine though.
    Re: Intex 18'x52
    FYI....the 18'x52" Intex Ultra Frame pool does NOT need to be cut for the Intex 2500GPH (633) fittings to work.
    Just in case someone else in the future is wondering and does a search.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Intex 18'x52
    Good to know, thanks for reporting back Sangster
    Re: Intex 18'x52
    We've a 20' Intex above ground pool. Came with a 1500 gph pump. Woefully inadequate. Pool was never clean. Recently purchased a 2500 gph pump online for under $100.00. If you purchase an 18' - 24' pool, dont even open the pump box. Sell it on CL or eBay and order a model 633T 2500 gph pump. They can be found online for under $100.00. HUGE difference for just a few $ more.
