Thread: CH concentration level between top and bottom of pool
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,051
    So I have been fighting high CH levels for about 2 years and I have finally followed Richard320 idea of directing a downspout to add rain water to the pool. The downspout goes into the skimmer basket. When the pool get full I drain the pool from the main drain only. So I am wondering if there is a higher concentration of CH at the bottom of the pool as to the top of the pool which has the added rainwater. Keep in mind that the pump is not circulating the water when it is raining. What would be your thoughts? Thanks
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Re: CH concentration level between top and bottom of pool
    As long as the pump has been running since the last time it rained significantly, the CH concentration should be just about exactly the same everywhere. That would not be true while it was raining, but it won't take the pump all that long to throughly mix everything together. Once mixed the concentration will remain uniform.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,051
    Thanks Jason, my idea is to remove as much concentrated water as possible so that I can reduce my CH levels quicker.
