Thread: opening my pool
    opening my pool
    Live in NC
    Temp is 65 but this time on the year it will hold 80 during the day and 50 at night.
    pool size is a 30' round 25,100 gallons
    Salt water pool
    Sand filter
    1.5HP motor
    Water is a little cloudy
    Don't know the PH getting a test kit and some salt today and a container of shock.
    Any advise on opening this thing would be great I do have a vacuum and all the tools to get things done, just need to know the steps on how to do it so it's done correct the first time.
    -Matt
    Re: opening my pool
    Take a look at the opening an above ground pool article in Pool School. In-ground pools are slightly different, but most of the steps are the same.
    Re: opening my pool
    Skip the "shock" and buy either 10-12% chlorine or bleach. I've found all the information I need from signatures (Pool School, Pool Calculator, etc)
    If you're confused/stuck and searching doesn't turn up a good answer, start a new thread. Everyone is very helpful.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Aug 2009
    SW Wisconsin
    518
    Re: opening my pool
    you are off to a good start by joining this forum..they will help you have a perfect pool!! Use the pool calculator, and get a "base" reading on ALL of your pool water paramenters...temp, pH, Chlorine, CYA, etc...and then plug those numbers into the pool calculator..it'll tell you what you need to add to make your pool pefect!
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Re: opening my pool
    I checked out the pool school and did a ton of reading. So I shocked the pool let it sit all day and scrubbed the pool with a brush sat all night with the pump on. Next day vacuumed the pool and put in my salt let it sit for a few hours after moving the salt around and checked the levels, had to put a half a bag more waited over night and the level is good now. Thanks for the help and the direction.
    -Matt
