Thread: Intellifo optimal speeds for heating
    I have been running my pool mostly at 1600 RPM which keeps my intellichlor all green for flow. I'm just starting up my heater for the season. Should I be running it at higher speeds when I use the heater or the same? Thanks
    Re: Intellifo optimal speeds for heating
    Which heater do you have?
    Support the site
    Jan 2012
    340
    Let the heater tell you. If it has insufficient flow, it will let you know and not run. Find what speed it likes and bump it up a couple hundred rpm to account for your filter getting dirty.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by amwexler
    Intellichlor is suppose to operate down to 25 GPM and you should have a lot more flow than that at 1600 RPM. Do you have a bypass for the cell? If you close off the bypass, you might be able to lower the RPM.
    Mark
