Results 1 to 20 of 20
Thread: SWG Survey
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    SWG Survey
    Hey all,
    I know everyones situation is different... but i wanted to get a feel for what the range of answers is...
    I have a pentair 40K gal SWG on a 16 k pool in Baton Rouge, Louisiana. I have been running mine between 30 and 40%
    What percentage do you run your swg on? Please list your pool size as well, and your location geographically.
    Thanks!
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    SWG Survey
    25-30%
    16 x 42 x 24 IG Vinyl True-L, 27,000 gallons, full width steel steps, 8' Cuddle cove swimout, 2 X Colorlogic 4.0 LEDs, Hayward Tristar 1 hp 2-speed pump, Hayward SwimClear C3025 Cartridge filter, Hayward Aqua-Plus PL-PLUS Controls + Chlorination, Hayward low-Nox 400K BTU heater, Tigershark QC, TF-100 test kit
    woohoo's Avatar
    Feb 2012
    Collierville, TN
    33
    Re: SWG Survey
    I am looking forward to the results of this survey. Good thread topic. I am on my first season and just turned my IC40 on yesterday at 50%. I suspect I will have to adjust it up from there given I am running a 40K cell on a 33K Gallon pool. Looking back, I wish I would have bought the IC60. Given CYA at 80, I am going to try and dial it in to 6ppm FC. Anxious to hear what others are running their units at.
    33,000 Gallon Vinyl Liner In-Ground Pool
    Intelliflo VS Pump; Triton II TR100 Sand Filter with Plumbed Waste Line
    IC40 SWG Cell; Easy Touch 4 Control Panel; Polaris PB4-60Q Halcyon Booster Pump
    Polaris 280 Automatic Cleaner; Dedicated return line; 1/2 Full Beer, Something on the Weber;
    AND, most importantly a TF100 Test Kit and a SpeedStir.
    dremin2flyhi's Avatar
    Jun 2010
    Darlington, SC
    121
    Re: SWG Survey
    35% -- 13,500 gallons ---pump on all the time in low speed -SC
    24' x52" Sharkline Venture (May 2016) ABG (13,500)
    Hayward S180T15932S --Sand filter/ Flo-Matrix pump pack
    Aquatrol-RJ SWG-- Nitelighter NLMC
    Dolphin E10
    Duraspa G2- Premium hot tub --Rotomold style
    38,539
    Re: SWG Survey
    Interested to see this too ... don't forget your cell size if it is not in your signature
    Dec 2009
    Central Massachusetts
    2,690
    Re: SWG Survey
    IC-40
    14,000 gallons
    25-30%
    Pump run time 10 hours 8am-6pm
    Cya 40
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Re: SWG Survey
    AutoPilot SC-60 - 19,000 gallons, 17%.
    [[[So many factors affect the percentage required (CYA, direct sunlight hours, swim hours, SWG size, pool size, water temperature, and so on) that comparing percentages really doesn't tell you very much.]]]
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: SWG Survey
    Also run time is an important factor. Remember a cell is designed for a daily output based on 24 hours of run time.
    Sep 2011
    Montgomery Texas
    89
    Re: SWG Survey
    Ic-40
    23000 gallons
    Run time 8 hrs.
    45%
    FC = 3.5
    Cya 60
    Still fine tuning but gettin close.
    24X38'ish 23,500 gallon Geometric with 10x10 spa(12jets), Pentair IC40 SWG, Pentair intelliflow(pool-spa), pentair whispersflow 2HP(booster spa jets), Two Polaris 1.5 Hp blowers, Pentair Wisperflow XF 3HP(2 6 foot water falls), Pentair clean&clear plus 520, Pentair Master temp 400. Intelli PH acid dispenser, Intellitouch with iPhone and iPad control. Two 45000 BTU fire bowls and one 60000 BTU fire pit.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: SWG Survey
    I suspect that cya, sunlight, and run time will be the ruling factors on residential pools.
    MattM's Avatar
    Jul 2011
    San Diego, CA
    299
    Re: SWG Survey
    ic-60
    24K gallons, covered
    12hr pump time, 11hrs SWG
    intellichem managed
    ~55% most days that we swim,
    ~30% on days when cover not opened,
    cya 33, FC 3.5-4.5
    We swim about every other day for 1-2hrs
    and weekly group swim lessons for neighborhood kids
    24K gallon inground gunite/pebble sheen pool, 34'x16' 4-7.5ft deep, 750sq ft solar, pentair ultratemp, intelliflow vs+, ic60, intellichem w/ acid pump, quad de 100, intellibright 5g, intellitouch i5-3s with Screenlogic2, 3" primary piping - 2.5" at equip pad, auto switched deep heating and main returns, automatic safety cover w/ electronic lock and embedded recessed undertrack, sealed stamped concrete deck, dolphin deluxe 5, started up December 2011.
    SWG Survey
    Expanding my response
    40k cell
    25-30%
    27000 gallons
    Pump 2 hours high, 11 on low
    CYA 40
    Central MA
    Jun 2011
    Long Beach, CA
    2,790
    Re: SWG Survey
    Jandy aquapure 1400 40k cell
    60%
    6 hours of pump time
    16k gallons
    82 degree water
    CYA 70
    A lot of swimming already
    Last summer:
    80% with 16 hours of pump time
    88 degree water
    CYA 80
    But the wife taught lessons for 6 hours a day with a lot of little kids.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,091
    Re: SWG Survey
    - Aquarite t-15
    - @6,000 gals pool size
    - set at 10%
    - runs when solar energized probably 6 hrs in the cooler months and 1-2hrs in the hot months
    we usually turn it to 50-60% when we are expecting a heavy bather load. I keep a very high FC usually 10.
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    422
    Re: SWG Survey
    Most peoples guidelines seem ok, but will vary based upon swimmer load, debris in pool, sunlight, CYA.
    Just once you get it working you will just test for FC and TC as normal until you find the right balance. Also when or if you
    shock your pool you will run at full open for 2o+ hours.
    Otherwise the hotter and more sun you will burn up more Chlorine, and heavy loads will do the same.
    I run mine for 12 hours at 30% on average in the summer for a 26K pool and pump at appx Variable speed punp at appx 40%
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: SWG Survey
    Aquarite T15
    35% now
    55-60% in full swim season
    DFW area
    Full sun from8am till 7:30pm
    Run time now 5 hours
    Swim season 9-10
    CYA 35 now dialing up to 60 now
    Few swimmers and a Lab.
    FC 3.5 now dialing up to 6.5
    77* now
    29K pool with Diamond Brite
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: SWG Survey
    Goldline T-15 Cell 1.45 lbs/24 hrs
    40% setting
    Varying run time from 8 hours in the summer to 1 hour in the winter but I usually keep percentage constant.
    20k gallons
    <- Location
    Mark
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: SWG Survey
    Quote Originally Posted by ping
    60%
    16k gallons
    82 degree water
    CYA 70
    Last summer:
    88 degree water
    CYA 80
    Betting you have a couple of kids not getting out of the pool to take care of bidness there bro!
    Jun 2011
    Long Beach, CA
    2,790
    Re: SWG Survey
    Quote Originally Posted by Lershac
    60%
    16k gallons
    82 degree water
    CYA 70
    Last summer:
    88 degree water
    CYA 80
    A lot of 2-4 year olds will do that.
  20. Back To Top    #20
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Re: SWG Survey
    I run my IC40 at 10% 24 hours/day on a 22000 gallon pool.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
