Results 1 to 8 of 8
Thread: New Pump Not Running?
    Hello and Thank you in advance for any help!
    I'm new here so if this is in the wrong place or previously posted forgive me.
    Inground spa/pool
    I have just replaced a 1.5hp motor with a new one after watching the old burn up.
    put new motor in exactly as old came out, all went well.
    Now when I push the button to turn on the air blower & pumpfor the spa, only the air blower comes on so I get air flow through the jets but no water.
    They are both on the same circuit so I know there's power.
    They both work off the same button, so I assume the button works (I hope, because it is set in concrete)
    Motor does not humm at all, just does not go on.
    Any other ideas as what it could be?
    Thank You
    B
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Re: New Pump Not Running?
    hi, welcome to tfp!
    Did you check the back of the pump for an on/off switch? Did you fill the pump basket with water?
    Love TFP? Become a
    TFP Supporter!
    No switch on back of motor. I opened the back just to be sure.
    I did fill the basket with water. pump will not turn on still.
    Thank You
    Jul 2009
    Houston, Texas
    9,376
    Interesting... Can you post a picture of the pump and the wiring?
    Love TFP? Become a
    TFP Supporter!
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    I wouldn't suppose you replaced a 120v motor with a 240v motor?
    Correct pump was installed.
    I will get some pics put up on Monday
    Thanks for your help
    22,542
    My guess is that there's a fuse or breaker after the switch. and it's blown or tripped. The switch could actually be pulling in a pair of relays and the pump one is where the problem is. Pictures of the pump and the equipment will help.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Do you have a meter with which you can confirm power to the motor terminals? Assuming that it is wired correctly at the motor, power to motor and motor not running = bad motor. No power to motor = problem further upstream.
    Also, make sure there isn't a disconnect switch over by the motor still switched off. I've done that before.
