Thread: Cleaning the rails, etc.
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    Hi all!
    Well, I made the mistake of not covering the pool for the first time ever- what a mistake- and now of course I have a BIG clean up job ahead of me. The top railings around the pool are covered in black smut/mildew/ pine-tree sap. What is the best way to remove this without damaging the finish on the railing? I was thinking once I got the water clear and all the water boatmen out. I could get in with some clorox clean up or bleach/water solution and scrub with a soft wash cloth or scrub brush. Any suggestions on the best way to do this without a big headache?
    I'm also tempted to just drain the pool partically, but how low can you drain an AGP without risking damage to the liner?
    TYIA
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    22,553
    Re: Cleaning the rails, etc.
    Diluted bleach is the first thing to try. You can also use a Magic Eraser on it and it doesn't add anything bad to the water.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    If you have a trichlor tablet around, try rubbing it on the stains or leaving it sitting there for a little while. I expect that will clean it up, which just means the stains will go away eventually with shocking.
