Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: New Intex AGP/Sequoia Wood Grain. HELPPPP!!!
    Hello all. I found this site about a week ago and with out the info here I would have started this project with both feed already in a grave.
    I'm really in need of more info on leveling the foundation of my build. I will be posting as many pictures as possible and would appreciate any constructive criticism to keep me in the right path. I also will be installing a Walkmaker cement walkway leading from my patio to the pool and around it.
    Thanks In Advance!!!
    I am here: http://tapatalk.com/map.php?qh0oim
    Oct 2011
    New Caney, Texas
    414
    Re: New Intex AGP/Sequoia Wood Grain. HELPPPP!!!
    Welcome to the forum lsmith1
    Looks like you are off to a good start. just take a 2"x6" crown up (bow) with a level on it are work it around the perimeter. take a little dirt at a time. Someone I know took to much and it settled after trying to fill it back.
    Be sure to read Pool School and get a good test kit.
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    Thanks George!
    I am here: http://tapatalk.com/map.php?nsxomz
    Rain!!!! Ahhh!!!
    I am here: http://tapatalk.com/map.php?4njzqr
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    I used a 2X6X12 with a 4' level taped to it, pounded a stake in the center of the site and then connected the 2X8 to the stake so it could swing in circles, then just rotate the board and assess level. Buy a level that can be viewed from the top, after alot of leveling I got my site within 1/2 of level.
    Level is key, the site has to be level.
    Aug 2011
    Virginia Beach
    295
    I think I know how I'll be leveling mine soon- Thanks Cramar!
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
    Thanks Cramar!!! My slope is pretty significant so I'll be using a Dingo/Toro for the heavy dirt removal next I will use your method to get the surface completely level. I'm thinking of going with 2" foam board instead of the sand, then putting the heavy duty tarp on top.
    I am here: http://tapatalk.com/map.php?0dh55c
    UPDATE!!! Dingo Does Not Work On Clay!!!! Had to go back to HD and rent the sod cutter to finish grading to a level surface. Also with the help of my wife and kids on the shovels.
    I am here: http://tapatalk.com/map.php?z2dj5y
    More pics of progress.
    I am here: http://tapatalk.com/map.php?rclh3z
    More leveling!
    I am here: http://tapatalk.com/map.php?lkayfz
    Finally can lay the tarp.
    I am here: http://tapatalk.com/map.php?1giacu
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    I feel your pain, my site was largely clay as well, I had to resort to chipping away small chunks about 6X12 inches at a time, the worst of it was 8 inches deep....slow going! Just keep at it, getting as level as possible is perhaps the most important part.
    Also, I took an old broom handle and screwed it to the side of the board, it helped easily move the board around the site.
    Good luck!!
    Thanks Crama ! The pool Is up with less than a inch off level. Still have a lot of work to do.
    1.Remove excess Dirt
    2.Complete cement walkway and stain patio and walkway
    3.Landscape the whole backyard
    I am here: http://tapatalk.com/map.php?y2vdar
    racerboy6996's Avatar
    Aug 2010
    Albemarle, NC
    103
    Congrats on getting your pool up
    Intex 16ftx32ftx52in rectangular / Hayward 2 speed pump / Hayward 21in sand filter / Intex SWG / still saying solar panels coming next year
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Congrats on getting it up, looks like you had a good crew there
    Aug 2011
    Virginia Beach
    295
    Congrats! We (my 8 year old & I) will likely start doing ours next week.
    Virginia Beach, VA
    Leisure bay hot tub
    Yes Linen they were a great help.
    I am here: http://tapatalk.com/map.php?isdp42
    I took off today but will be back at it first thing after the kids orthodontics appointment in the morning.
    I am here: http://tapatalk.com/map.php?zmjiyo
    Update!
    I am here: http://tapatalk.com/map.php?4mg1pc
  20. Back To Top    #20
    Update!
    I am here: http://tapatalk.com/map.php?unwiji
