Thread: Need help wiring new hayward super ii dual speed pump
    May 2008
    Ridgewood NJ
    16
    Just received my new super ii dual speed pump. It will be replacing a single speed pump and i see that there is no built in toggle switch to change motor speed. I will be wiring it to the same intermatic timer and was looking for simplest solution to help get this going. I was planning to use the pump in low speed except for vacuuming. What type of toggle switch do I need and what is the easiest wiring solution,
    Thanks in advance,
    Len
    35,000 gallon IG pool. pebblefina sapphire galaxy finish
    2hp Hayward 2 speed pump, Hayward DE600 grid filter, Hayward Heater, Polaris booster and 280 cleaner
    Liquidator
    Re: Need help wiring new hayward super ii dual speed pump
    You need a SPDT toggle with a high enough amp rating to handle the amps your pump requires. You wire one of the two power wires coming from the timer to the pump common line. The other power wire from the timer goes to the center terminal on the switch and the two outside terminals on the switch get wired to the high and low speed connections on the pump.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Sort of like this...
