Thread: Opening Refresher Help
    Hi Guys,
    After extremely warm temperatures for March in East Tennessee we decided to open our above ground pool today. However, I need a refresher course.
    We closed pool down using the BBB method, the past years we have open to clear beautiful water, however this year the pool is a little cloudy. Not sure if this is because of warm temperatures or because our tarp style pool cover is a little warn and after I have looked at it more it is almost see through.
    Before I started filling up with water, I took a sample and here are my results
    FC 0
    CC 0
    CYA 10 ( I did allow sample to reach room temperature for this test, PH, and TA)
    PH 7.6
    Alk 110
    I didn't check Calcium-should I?
    Like I said this is a sample pre-fill up with city tap water- Do I need to take another sample once the pool is full?
    I plan to start running the pump tonight once water level is complete-
    How do my numbers look?
    Also will the cloudiness go away up circulation and good vacuuming? There was a couple of leaves and some dirt in bottom?
    Refresh me here please-
    1. Do I need to go ahead tonight an add my bleach amounts?
    2. Retest in morning, etc
    3. I haven't purchased cya yet, but plan to tomorrow and adjust to 40.
    I only trust input from TFP...best decision I have ever made to switch from Baqugoo to BBB!
    21 ft Round Dough Boy
    3/4 horsepower Dough Boy PowerPak II pump
    Vinyl Liner
    baqua goo convert
    38,524
    Re: Opening Refresher Help
    I have never done an "opening", but since the water is cloudy and FC is 0 I would think you may want to do the shock process to be sure everything is perfect (even though CC appears to be 0 too).
    I would think you fill, circulate awhile, full set of tests, adjust pH as needed, and then follow shocking procedures (maybe add a little CYA before this).
    The cloudiness may go away with the filtering, but if nothing is growing, the shock process will be VERY short.
    Better safe now what blooming later right?
    22,553
    Just adding to what Jason said.
    If you tested without the pump running you definitely need to test again after running the pump a while before you add or adjust anything.
    Bringing it to shock might be a good idea.
    Everything is up and running-
    Have been running pump for 30 hours or so...vacuumed and got most of the dirt out, but still a small amount at bottom- have topped up to shock level per CYA/Chlorine chart for CYA of 20- however pool still has a little haze to it-
    Should I continue to shock? I haven't back washed yet but will tonight before I add chlorine, etc.
    The last time we had haze was when we used baqucil and it was a nightmare that we could never get rid of until we switched to the BBB method-
    Am I over worrying? or is there something else I should do?
    HELP!
    When I did recheck this morning CC were at 0, FC had dropped to 4.5, and ph was still around 7.5-
    Vinyl Liner
    baqua goo convert
    38,524
    Just keep raising FC to shock level until you pass the over night test. The better you keep it up there the faster things will go. For some this has taken weeks, yours sounds like it is starting to clear.
    Did you read the shock process?
    pool-school/defeating_algae
    pool-school/shocking_your_pool
