Results 1 to 9 of 9
Thread: Am I not using enough chlorine?
    Mar 2011
    Cowden, IL
    15
    We opened our pool to a green swamp
    My first reading was
    FC-0
    pH-8.2
    CYA- less than 20
    I added the muric acid, got the pH down to proper levels.
    Added stabilizer/conditioner to bring up the CYA
    Brought the FC up to 10 (according to the CYA/Chlorine calc.)
    It took 20 minutes and the pool was a cloudy blue, but the green was gone!
    It's been getting slightly better every day, and I'm brushing like crazy. The walls still have green algae on them, I can now see this as the water gets more clear, and the whole outside rim of the pof the pool and cove are covered in green algae.
    This has been going on for 8 days.
    My question is, should I increase the FC level to more than 10, or just keep on keeping on?
    Thanks in Advance!
    13K Gal, AG (buried in-ground) pool, Pentair SD40 19" Sand Filter, 1.5 hp Dynamo pump
    37,391
    Re: Am I not using enough chlorine?
    How much CYA did you add? What were you targeting?
    You should shock to the level that you expect the CYA to rise too. FC @ 10 was correct for CYA of 20, but if you added alot, then you may need to go higher based on the chart.
    How often are you testing your FC and raising it back to shock level?
    And is your pump/filter running 24/7? Cleaning when required?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,100
    You most likely need more chlorine. What is your CYA now?
    Are you maintaining 10ppm at all times, or is it dropping between tests?
    Edit: Too slow but my questions are slightly different so I posted anyway.
    Mar 2011
    Cowden, IL
    15
    I added enough to bring the CYA to 40 (40 has worked great in the past), It's just now reading 30.
    The pump is running 24/7.
    I've been checking it 4 times a day, it ends up dropping at least twice between those 4 checks.
    Butterfly's Avatar
    South Carolina
    10,045
    About 24 hours after the CYA has dissolved, assume it is there and increase your shock level accordingly.
    IOW, if you added enough CYA to reach 40, your shock level should be about 16.
    You're done SLAMing when:
    Mar 2011
    Cowden, IL
    15
    Thanks all, I've been keeping the FC at 16 since the 29th. The water is sparkling clear, but there's still algae on the bottom, and some on the walls. We leave for vacation on the 10th, I'm hoping to have it cleared up before then so the ppl taking care of our pool don't have to mess with brushing it while we're gone.
    30,107
    If you can see it on the floor and walls, brush it up or vacuum it up to get it either filtered out or vacuumed out. With crystal clear water, it is probably dead algae but it needs to be mechanically removed through filtering or vacuuming. Keep your FC at shock value while you are doing this.
    Mar 2011
    Cowden, IL
    15
    It doesn't seem to budge when brushed or vacuumed. Is it possible for algea to stain?
    Yes, algae can leave behind organic stains. Organic stains will fade over time, slowly at normal FC levels, more quickly at high FC levels.
