Thread: "Rinse" position on multivalve
    May 2009
    Dallas, TX
    782
    Do I understand rinse correctly as: The same water path as "filter" position, but sends water to waste line instead of back to pool?
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: "Rinse" position on multivalve
    Yes. Flushes the pool side of the sand after backwashing.
    38,262
    You got it.
    I use it when backwashing ... switch between backwash and rinse until the backwash is clean. I have heard bout using it when charging with new DE also so that any DE that makes it past the grid does not end up in the pool (although I have never seen this to be a problem).
    May 2009
    Dallas, TX
    782
    Thanks for the quick responses!
    May 2009
    Dallas, TX
    782
    Quote Originally Posted by jblauert
    I agree it should not be a problem. However, in my limited experience, as well as my limited expertise, and possibly my limited intelligence, I always seem to get a little bit of DE back into the pool when recharging. Just enough to be annoying...
    Next time I backwash/recharge I will follow a slightly different procedure. Instead of recharging in filter position, I will leave the multivalve in rinse while I recharge with DE. I don't think it will waste too much additional water because this part of the overall procedure happens fairly quickly.
    38,262
    Quote Originally Posted by Beez
    I may pay attention a little more and see if any is sneaking past for me as well ... I agree it really should not be very much water loss at all to leave on Rinse.
