Thread: Type of Tubing for Acid Injection
    RCDuck's Avatar
    Jun 2008
    TEXAS
    11
    My pumping system for acid injection uses what appears to be polyethylene tubing from the pump to the injection port. After about a year of use the tubing seems to be a little brittle and is cracking where it attaches to the pump. Is the polyethylene tubing the best option or would I be better off using something else that is more UV resistant... Santoprene? I assume the tubing in the pump itself is santoprene, is there any reason not to use it for the supply tubing as well?
    26,000 IG Pool (Gunite w/Premix Marbeltite), Jandy Stealth 2 speed pump, Jandy CL460 Cartridge, Jandy SWG, Nature2 (Disabled), Ultrapure Ozone, Polaris Cleaner, Jandy PDA controller
    22,553
    Re: Type of Tubing for Acid Injection
    Just look for UV stabilized tubing. It's most likely going to be black in color. USPlastics sells it. I don't know if the big box stores will have it.
