Results 1 to 9 of 9
Thread: Umbrella Holes in Pool Deck
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    So i've read several threads where folks use some PVC fitting to create an Umbrella hole in their pool decking. On tread talked about how they worked with the concrete guys to incorporate them in the pour.
    My concern with this is placement. Seems to me that I won't know where i really would want an umbrella until several weeks into the summer. I won't know where i end up sitting, where i ended up laying, where the wife likes to sit, kids etc.
    Does anyone have any experience with doing a core drill on pool decking concrete after it's cured some to make umbrella holes? My deck (patio too) will be poured out of some "special pool mix 4000 psi" that i understand will not have much (any) aggregate in it. If that makes any difference on the ease of drilling.
    My concerns are getting a drill bit to start a hole without jumping around, and with the PVC holders they extend a little bit farther down underneath the concrete, if i drill a hole all the way through i'd hit dirt or gravel. If i stop short the hole would be maybe 3" deep, is this deep enough, or does it give the umbrella pole leverage enough to crack the concrete? Or would the umbrella pole just bend?
    Another concern would be what would i do if i hit rebar? Can a diamond drill bit drill through rebar? (that would suck, off by 1/2")
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Re: Umbrella Holes in Pool Deck
    I'm concerned about drilling holes in my deck just to install pool slide flanges. With big holes like that, I'd think you'd risk some pretty good fracturing, even with a hammer drill. I guess it would just depend on the mix/curing of the concrete in place.
    Kansas City, MO
    13500 gallon Foxx vinyl sport pool--inground (1988)
    Cristal-Flo sand filter
    Ray-Pak 406A digital
    1.5 HP single speed
    400 gallon Heldor inground spa, octagon
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Another option is just to have a bunch of sleeves installed, anywhere you think you might want to sit. Consider sun angles too!
    Jan 2011
    Albuquerque
    72
    Good question - I've been wondering about the same things also. I don't have the same options as you do as our deck is already poured, but I figured I'd wait a season before drilling holes for an umbrella or two. Has anyone else on TFP done this? I'm in a windy area and don't plan on having the umbrella out on windy days, but we do get the odd gust out of the blue and it can put some force on the umbrella so I'm worried about drilling a hole and causing cracks to form due to the stress (but I also don't like the looks of an umbrella stand with sand bags or other weights on it to hold it down). Also, I'm assuming that I'll need some sort of cap to install over the hole in the wintertime so water won't get in and freeze in the space.
    Jun 2011
    New Smyrna Beach, FL
    31
    How about a concrete hole saw? They sell them at home depot. Maybe one of your friends has one.
    1: 10,000 gals in the ground plaster, Hayward pump SP2715X20 2hp
    2: Aqua Rite Electronic Chlorine Generator / T-Cell-15, Hayward Pro-Grid DE Filter Model DE3620
    3: AquaCal Heat Pump, Astrlite SP0580S Under Water Light
    4: Port PolarisCaretaker, TFTestKit-100
    Apr 2011
    Warner Robins, GA
    245
    I have seen pipes (metal) installed after the holes are drilled into the concrete. The pipes range from a few feet to 6 feet. This provides relief from cracking due to the umbrella pole moving around.
    A few cons I could see however, is you better KNOW exactly where your plumbing and/or electrical is so you dont hammmer the pipe down into it!!!!
    16 x 32 Grecian Vinyl. Salt-Aqua Plus PS-4, Hayward Pro Series Sand Filter, Hayward Ecostar SP34000vsp, Gulfstream HE-125-T-A Heat/Cool heat Pump
    I wanted umbrella's but my husband didn't want to have holes in the concrete so he came up with this idea. It works great! We still get the shade in the pool without the holes in the concrete.
    18x 36 vinyl in ground, SWG, sand filter, Hayward 1.5hp super pump,
    Nov 2013
    Baltimore, MD
    5
    We had an umbrella socket installed in the shallow end of our pool during construction. It's on bench that extends out from the steps. Works nice, but you need a stainless or aluminum pole that can withstand the salt water.
    27,000 gal IG free form roughly 20'x42'
    Concrete/plaster
    PC2000, Pentair cartridge and SWG
    Jul 2013
    Waxahachie, Tx.
    446
    Quote Originally Posted by gigicarmical
    I like that idea. Thanks for sharing
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
