Thread: Non-return valve - replace?
    Hi,
    I'm trying to ascertain if this non-return valve needs to be working. Here's a picture:
    The plunger(?) managed to bend itself somehow:
    Do I need to replace this? The pool seems to run fine with the water just passing through.
    22,553
    Re: Non-return valve - replace?
    The only issue with it not being there is that water could back into the pump from the filter. If that's not happening then it's not needed. I wouldn't worry about replacing it unless you hqave an issue. My system doesn't have one at all.
