Thread: Hayward Vari-Flo Control Valve
    Jun 2010
    NW Foothills of North Carolina
    21
    I have a Hayward SP714 T1 Valve that has a crack where you install the pressure gauge (I tightened the gauge too tight). I fixed it using JB Weld about two years ago, but this year it has started to leak again, so I thinking to replace it.
    How hard if it to replace one? Will I need to do a lot of plumbing? And is there any difference between the SP714 T1 and the SP714 T?
    21K gallon, 16 x32 IG Vinyl, 3/4 HP Hayward Superpump,
    200 lbs Sand filter, Full sun all day
    Re: Hayward Vari-Flo Control Valve
    Replacing a multi-position valve is at the difficult end of PVC plumbing, still PVC plumbing in general isn't too bad. The main issue is that there are quite a few connections in a tight space that all have to line up just right. It takes some methodicalness and measuring everything two or three times
    22,549
    If you're handy at PVC plumbing it won't be much of a problem. As Jason said, you have to measure and cut carefully but it isn't too difficult to get everything just right. Since the valve has threaded connections you can always unscrew them and start over if it doesn't work out right.
    As far as I can tell the T1 is just a later model of the T but the measurements are identical.
    Jun 2010
    21
    I have no PVC experience, but my brother-in-law in a plumber, so if I have problems at least I have someone to call.
    I put some more JB Weld on the crack, and it's holding. But I think I'll order the T1 so when/if the crack starts leaking again, I'll have it.
