Results 1 to 17 of 17
Thread: First Salt Cell Cleaning
    New to SWG. Moved into home with SWG pool (I think it was installed 2008/2009) in the fall. AquaRite controller with Hayward TurboCell T-15.
    System was working fine going into the winter, but not generating chlorine now. Solid light on low salt and inspect cell. I know it might be toast, but cleaning the cell sure sounds like a better option to me.
    Turned power off, loosened fittings and removed cell. Now, how do I use the 1:4 acid/water mixture? I'm thinking I can stand it in a bucket, but I am a little wary of the control cable. Any suggestions? Thanks.
    Howard
    20,000 Gallons
    Cartridge/SWG
    Gunite
    Memphis, TN
    37,399
    Re: First Salt Cell Cleaning
    I am not 100% the best way to clean the cell. Can you actually see white scale on the metal fins? If not and they look ok, there is really nothing to clean.
    I think the check cell light will automatically come on every 3 months or so to "remind" you to inspect the cell ... this light may not really mean there is a problem with the cell.
    It is not generating Cl because of the low salt condition. Have you independently checked the salt level to confirm that it is indeed not just low? ... if it really is low then adding salt my solve the problem. If the salt is not really low, the lower reading from the cell usually means the cell is starting to go bad and cleaning may or may not help.
    I think the cells generally have a life of 3-5 years and you may be in the middle of that.
    Just got my first salt test strips today. Controller says 2100ppm and I will test, as well as take some water to the pool store. One thing I've read here is to not add salt just because the controller reads low.
    Visual inspection of cell (can really only see a little on the ends) showed some misc gunk. So I'm hopeful the cleaning and salt add (if needed) will be it. Thanks.
    Still hoping for some insight on cleaning in the bucket.
    Howard
    20,000 Gallons
    Cartridge/SWG
    Gunite
    Memphis, TN
    37,399
    I think the easiest way is if you have the stand as shown in this YouTube video.
    However, I think you are able to just lay the whole cell in the solution while keeping the cord dry.
    Feb 2012
    North Texas
    19
    Quote Originally Posted by HowardL
    Howard
    Hayward makes a cleaning stand for this purpose. If you don't have one you can use a bucket but make sure to stand the cell upright with the control cable at the top of the bucket. Do not submerge the control cable end in the bucket. If you could somehow "cap off" the end opposite the cord, stand the cell up in the bucket and pour the diluted acid into the cell to clean it. This is what I do to clean mine.
    mvk111's Avatar
    May 2011
    Tampa, FLorida
    62
    Pool stores also sell a SWG stand that snaps into the bottom of the cell and then you can fill the inside with the mixture without getting the exterior wet at all. It just basically caps the bottom of the cell allowing you to fill the inside. I saw it the other day and it looked like a clever idea.
    15x30 free form (10,500 gal) SWG
    Gunite, Game depth 3.5-5-4 ft, 1 hp Sta-Rite Super Max 2 speed pump, 53' Sta-Rite system 3 DE filter
    Pentair Intellibrite LED
    Pentair 125k BTU ultra temp heat pump,
    Screen Enclosure
    TF-100 Test Kit
    Well, since I took the SWG cell out to clean, thought I might as well clean the cartidge filter while I was at it. I can't believe how filthy it was. In process of putting Humpty Dumpty back together again now.
    Question: how tight do the cartridge filter clamps need to be? Hand tight?
    Thanks.
    Howard
    20,000 Gallons
    Cartridge/SWG
    Gunite
    Memphis, TN
    Testing salt level now with test strip. Controller, which shut down due to low salt) said 2100ppm. I will see what test strip says, hook the SWG back up and start powering up.
    Any suggestions, comments or warnings? Thanks.
    Howard
    20,000 Gallons
    Cartridge/SWG
    Gunite
    Memphis, TN
    Salt test strip says (if I am reading it correctly) 5.0 - 5.2 which equates to about 1900ppm. So, roughly the same as controller.
    At this point, I think it's time to turn everything back on and add about 200lbs salt.
    Howard
    20,000 Gallons
    Cartridge/SWG
    Gunite
    Memphis, TN
    37,399
    Well, that could be good and your cell may work after all.
    How did you come up with 200 lbs?
    According to the poolcalculator.com for a 30,000 gallon pool to raise from 2000 to 3200 is 300 lbs ... of course you may want to start with a little less.
    Math error. Just added 280lbs. Thanks.
    Howard
    20,000 Gallons
    Cartridge/SWG
    Gunite
    Memphis, TN
    Jul 2010
    Ashford, CT
    346
    Some SWG's like Pentair IC models DO NOT produce chlorine unless the water is at least 53 degrees. Check your manual for this.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Aquarite is the same, +51*. Also every 500 hours "INSPECT CELL" will come on, this is normal. Hold the + to reset after looking.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Sep 2015
    Irving, TX
    1
    Quote Originally Posted by gcalahan View Post
    You can just buy a 2" expansion plug from home depot for a little over $ 4. I have used it multiple times and works for me with keeping the cell in a dry bucket. This is what I had bought:
    Oatey 2 in. Gripper Mechanical Plastic Test Plug-33401 - The Home Depot
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,853
    Another option is to cover one end with plastic wrap, hold it in place with a heavy rubber band, then stand it on end in a bucket. Pour the acid/water mixture in and let it sit for a while. Then very carefully pour it out, rinse and reinstall. Find a place to pour out the acid mixture on the ground. Do not pour it in the pool.
    chiefwej
    37,399
    I used duct tape and then added the acid mixture to the pool when I needed to lower pH.
    Using the GLX-CELLSTAND is probably the easiest method that won't leak. However, it's about $28.00. Not cheap, but not crazy expensive.
    The cell has a notch that makes using a rubber plug not work well. If you use a "Union for Aqua Rite Salt Cell GLX-CELL-UNION" (found one for $6.00) and a glued in 2" pvc slip (spigot) plug, that will work. If you want to dispose of the acid, pour it in a plastic bucket and neutralize it with baking soda first.
