Results 1 to 15 of 15
Thread: Retro fitting a Intex Filter Pump and Chlorinator Combo
    Hi,
    I have searched from end to end on this forum, and have not found a post that matches my situation. I have been using the Intex saltwater pump chlorinator and filter combo for about 3 years, on an Intex 15' x 48" metal frame pool. I would like to employ a sand filter this year, but do not want to give up the combo unit for chlorine generation, since it is still functional. Does anybody have any experience with disconnecting the pump and paper filter unit from the system, and tieing in a sand filter?
    My reasoning is that I would like to run the sand filter periodically over the course of the day, connected to a timer, and having the saltwater generator set for a specific time to match with one of the sand filter pump cycles. I have previously used a 1/2 HP water pump pool, farm, pond, biodiesel motor from Harbor Freight, to run the pool skimmer. It has worked ok, but has also been a pain in the keister as well, hence my desire to consolidate.
    hopefully this will generate some dialogue, and I can get on with my re-engineering project in time for swimming season that is just around the corner, in Houston.
    Kurt
    14'x28' 14k Gallon, Pebble Tec Finish, Sta-Rite IntelliPro VS-3050, Sta-Rite PXC150 Cartridge Filter, Intellibrite 5g Light
    Re: Retro fitting a Intex Filter Pump and Chlorinator Combo
    Welcome to TFP!
    It isn't very difficult to plumb the unit so water flows through the SWG without going through the pump or the filter. However, my memory of that unit is that the control electronics control both the pump and the SWG together, and won't run the SWG unless the pump is also on. I think you could cut the cord between the control box and the pump motor to defeat that, but if you did that the unit would never work normally again.
    I have done some further digging and discovered that it might work! For a test, I totally disconnected the pump from the power. I taped the flow sensor to "trick" it to believe there was abundant flow. I powered the unit and set the controls for a 1 hour chlorination. About 10 minutes later, I recieved a "91" low salt code!!!. This tells me that it is not missing the pump, and that once connected inline with the pump/filter; it should work correctly!!!
    When you decide to hook this up from a filter directly to the SWG, how do you plan to hook the pvc tot he SWG since the one end of the unit has a much larger connection?
    32 1/2 X 19 free form gunite pool ~ oklahoma flagstone ~ 569 sq ft stamped concrete deck ~ Jandy E Pump ~ RB 320 Chlorine Sanitizer ~ UPP 15 gal Ozonator ~ 4 LED Savis lights ~ 3 ft sheer descent water feature ~ spa
    check out the following post:
    custom-pvc-pipe-adapter-for-intex-pools-t28971.html
    I used the fittings mentioned by Raza. they are electrical fittings, but fit perfect for the 2" inlet and the 1.25" exit. I will try to get some pics of what I did. As far as I can tell, it should work great, but reflect on one of my electronics instructors who questioned you with the acronym "TSW" which meant "This should work...huh"?
    I will know for sure, as I plan to have the pool operational by the end of this weekend..
    I would love to see some pics cause the box adapters (electrical adapters_ are 1.5 inch and they would not seal properly with the intex nut for me anyway
    I believe the large adapter is 2", and then I had to reduce that connection down to 1.5"
    Do they make a 2" box adapter?
    Sorry I posted too soon. It looks like Lowes has them on their site.
    Thanks for the help.
    I would still love to see pics of yours and if possible what wires you disconnected to take power away from the filter/pump
    This is a first for me, but here are some pics of my home manufactured fittings for the Intex 56601E Saltwater System For Above ground Pool.
    This is just the two individual fittings. I will post more when it is all connected.
    Mas!
    todo mas!
    hard plumbed everything today and WOW what a difference over the hoses, however I have one freaking leak, exactly where I thought it would be. I disconnected and the filter and cut the power to the pump that part is fine. Then I ran directly from the hayward DE filter to the SWG piece of the combo. I used a 2 inch box adapter however I went from the box adapter directly to a 2 to 1.5 inch reducer. That didn't seal real well however my leak is at the intex 2 piece nut and the box adapter. I plan to take the box adapter out and get a new one and put a small 2 inch piece then into a reducer. What's the secret to fixing leaks. I will post a photo later tonight. Any input is appreciated
    I just ran the modified Intex SWG system through its first chlorination session. I am happy to report that all went well.
    That saves me about $200+ on an individual SWG!!!
    Can you supply me with the combination of fittings you used for the 2 inch side? No matter what fittings I use I cannot get a tight enough seal.
