Thread: 2 speed pump good price
    esim13's Avatar
    Oct 2009
    Denham Springs, Louisiana
    320
    I'm looking into getting a 3/4 hp 2 speed and I found this one...
    http://www.vminnovations.com/Product_74 ... Speed.html
    Just thought I'd spread the word since so many are looking into 2 speeds.
    10,408 gallon, 21' round, 52 in' deep AG, half in ground
    Artesian Clear Master Plus Sand Filter, Artesian Turbo King 2 hp pump, installed June 08
    GEAUX TIGERS!
    Pics taken 2012
    http://i941.photobucket.com/albums/ad25 ... CN0606.jpg
    http://i941.photobucket.com/albums/ad25 ... CN0607.jpg
    Re: 2 speed pump good price
    You can get that same pump for just a little less here.
    This particular pump is an above ground pump, suitable for short plumbing runs where the pump is located below water level.
    esim13's Avatar
    Oct 2009
    320
    Hi Jason, Can you recommend a similar pump for a run about 40'? I have an above ground so that's fine. My pump is running but it will not pressure up and move water. I moved the rod/shaft with a wrench so I know it's not stuck. I'm interested in the 3/4 2 speed because I'm running a 2hp now and figured I might as well change it out.
    GEAUX TIGERS!
    Pics taken 2012
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    I think I had the Dynamo on my last AG pool, it wasn't a 2 speed tho, that would have been nice... would be nice to have now.
    They are 115V only from what I see in the specs. Keep that in mind if you need 240.
    27000 gal 18x36 rectangle In-Ground built in 1978
    Vinyl liner, 3/4hp Hayward Super pump, single speed 3450rpm
    SWG: Hayward Aquarite AQR15
    Sand Filter: 300 pound sta-rite T-240BP-1, 3.14 sqft surface area
    K-2006 Test kit
    Actually, the Dynamo is a fairly good pump for an above ground pool with longer than normal plumbing runs. Compared to other above ground pumps, the Dynamo works better with long plumbing runs than most others. In ground pumps are usually "low head" pumps, designed to move water when there is relatively little resistance to flow. In-ground pumps are usually "high head" pumps, designed to push water against a lot of resistance. The Dynamo is actually a "medium head" pump, which is good for more flow resistance than the typical above ground pump, but not as good at high flow resistance as an in-ground pump.
    Just an fyi, AM charges a $8 handling fee while VM doesn't.
    3000 gal / Cartridge / AG / 1500GPH
    Lucky @ http://www.vminnovations.com
