Thread: Screened Room
    Screened Room
    Just found this board and impressed with all the knowledge that can be obtained and has been thought about on just a simple pool..
    I am in the process of designing out a pool for my kids, 18' ultra, but where I live in Florida, I have a huge amount of bugs in the evening hours, that would render the pool useless. Has anybody found or know of an inexpensive screen room that can be constructed to enclose a pool of this size (on a budget)? I have found screened enclosures up to 14' and that is it.... I have thought of using a metal framed carport (not wide enough) or even constructing a PVC frame and somehow attaching screen... But any suggestions would be appreciated.
    JoshU's Avatar
    New Orleans, LA
    542
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Oct 2011
    New Caney, Texas
    414
    Re: Screened Room
    Hi and welcome to the forum CuLaytur!
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    Re: Screened Room
    Thanks for the link... Exactly what I was looking for and didn't think to google "screen dome"... Found a bunch of hits... Also, looking at building a geodesic dome from pvc pipe or electrical conduit, the screen covering is about the hardest part of this....
    Mar 2012
    Tampa Bay, Florida
    166
    Re: Screened Room
    I'd be a little concerned about the typical thunderstorms and wind that we have in Florida. I see it is only rated for 40-45 MPH.
    A lot of Florida pools have aluminum reinforced screen enclosures, but they are expensive and they add to the homeowner's insurance rates.
    Perhaps a much cheaper solution to the bugs might be a couple of bug zappers safely located a bit from the pool (be careful of using 120VAC near any water and protect all circuits with a GFI breaker). I believe there are also propane powered bug zappers but I don't know the effectivenes of them. That might be an interim solution until a more durable enclosure can be installed.
    John (DIYer). Concrete, approximately 13,000 gallon in-ground pool with adjoining concrete spa. Approximately 40 years old. Hayward Super II pump for pool and legacy Anthony Sta-Rite bronze pump CF6 for spa, VA-26 filter,(2 sets), Rheem propane heater for spa. HASA Liquidator for pool.
